Australian Power Suppy Query for the CP-251 Moogerfooger Con
A query for those Australian users of the CP-251, I’ve recently come by one of these units however it came without a power supply. Would a standard 9V supply be sufficient or should I be ordering a particular unit to provide power?
Cheers
9-15 VDC positive tip 2.1 mm barrel connector should work fine. 9 V is optimal. It doesn’t use much current but 200 mA is a good value.
Have fun and make sure you sign up to KnobTweak for good usage tips!
Thanks Latigid
