Audio in, HOW ?
I just received my new LP Stage II. It all seem to work great. I’m sure the few things going on is my own doing (or not doing). I tried to run audio into the L.P. and nothing. Is there something I should be looking at. There is not a whole lot info in the owners manual. Thanks for any tips.
The next questions will be about midi.
Dean
Have you tried to play a note while the audio is running through? Also make sure the filter cutoff is fully clockwise.
Or, you can put a cable or dummy jack into the KB Gate input. Or, use a piece of gaffer’s tape to hold down a few keys while the Arpeggiator is going…or…the possibilities are endless! :smiley:
Would a EP-2 pedal work in the kp gate input?
Dean
Absofrigginlutely! You can even do tap tempo with the EP-2 by moving the pedal up and down!
