Assign mod wheel to pitch
I’m wondering if it’s possible to assign the mod wheel to pitch so I can drop the pitch of a sequence by exactly 2 steps without having to press a new key. Any advice would be much appreciated! Thanks!
Yes, that’s possible, you’ll have to use one of the two MOD sections:
  • set the MOD SOURCE to F.EG / PGM
  • push the CONTROLLERS button to open the MOD x CONTROL menu
  • set MOD WHEEL to 100%.
  • go to MOD x EDIT and set PGM SRC to CONST ON
  • turn the PITCH AMT counter clockwise to get the desired pitch while the modwheel is fully engaged.
If you think the PITCH AMT is a bit abrupt, you can tweak the MOD WHEEL percentage in the third point above to get a comfortable range.
That worked perfectly. Thank you!
