Arpeggiator Sync Slim Phatty
I am finally owner of a moog and it is amazing!
After some research here in the forums I found how to transfer the calibration patch to a new preset this way I have a good starting point for my new sounds.
I copied the calibration patch to the preset 00.
Now the problem I have is with the arpeggiator, it works fine without midi sync, but when I enable midi sync, nothing happens it continues to run like it was in eternal mode. What is strange is that all the other presets run in external midi clock just fine, but not my preset.
This only happens with the Arpeggiator, the LFO syncs properly.
Is there something im missing?
in your new preset, go to master menu → advanced preset, cursor and scroll to select arpeggiator, press enter.
scroll to Clok Src, it’s probably set to INT. Change this to GLOBAL.
The Calibration preset is older, and predates the new master menu/global ARP SETUP menu. In order for a preset to follow the Global arp clock setting, the preset CLK SRC (here in Advanced Preset menu) must be set to Global.
That should do it…
Thanks for the reply!
Worked :slight_smile:
