Arpeggiator sync in live band situation
Hi all,
I’m wondering if anyone else has tried the little phatty with a live band in arpeggiator mode. I see the sync modes INT, LFO and MIDI … also there is the key trigger situation.
What I want is the Arpeggiator to always stay on beat with whatever the root note is, just doing simple octaves. But what I find is that… at 60 bpm or something, if it’s stepping once a beat and you hit the key, it will hit the octave a second later… now… that’s cool as long as you hold that key. But when I hit the second key, it will immediately hit that note, and the octave will come a second after that key press.
But the problem is that I need to be hitting the keys exactly on time with the internal clock… which is obviously not even giving me a click or anything to sync to…
Does anyone understand this question? Do I need to hook it up to a drum machine… put it in latch mode? What?
Sadly this is my buddy’s LP SII so I don’t have any time to just sit and mess around with it and the manual.
-rich
I’m sure there is a way to do this, though I dont know how… but, after reading it, I’m just thinking, why don’t you put it in latch mode anyway? It would make it a ton easier to do, free up your hand to. When you want it to stop just press the button and it stops. Unless you want it to start and stop a lot with pauses in between… which in that case you would just do it regularly and learn to hit the key on time.
If latch mode does it, than I’m good with that for sure. I will try that ASAP. Sorry for the frustrated tone of my post, I just couldn’t stand the way it just… restarted with every keypress… It seems/feels more logical that the pattern would continue regardless of what key until the next note sounds… and that hitting a key wouldn’t have an effect on the … beat so to speak…
in txt form, what happens now is like:
1 . . . 2 . . . 3 . . . 4 . . . (this is what the band is playing, etc etc)
and then the arp is:
1 . . .2 . . . 3 . . . .  4 . . .
(in this case, for example, the two is hit early and the four late...  it just messes up everything!)
edit! The original track we’re trying to play was done in Ableton, but I have no desire to bring a laptop out for this particular band…
The track is streamable/downloadable here:
http://clark8.bandcamp.com/track/back-to-back
I thought for sure this was an issue addressed in one of the updates…
HB3! Oh awesome! Ok, I will make sure my buddy updates!
-rich
I thought that you could select between the arp and/or lfo restarting when you press a key and it restarting on the next tick of the clock after you press a key. I know this has been discussed before. Anyone?
Yeah, when I posted the question, it was not so much “this thing is broken” it was more like “the default behavior of this arp doesn’t make sense and we’re too dumb to figure out how to set it!”
Thanks, though, I haven’t had time to mess with it and my buddy hasn’t responded to my email.
I am a new LP II owner and can’t figure out how to set the arp clock so it restarts with every new key press, instead of sticking to an internal clock.
Anyone’s got info on this?
in the arpeggiator settings you find the option Sync Lock. if on, the arp will stay in the same pattern as the first note pressed, when off the arp will start on each new key press
