Im trying to made a control panel for the sub 37 in FLStudio using their Dashboard plug in.
I can record the values of almost any buttons but the arpeggiator section seems off limits to midi signals; only the ArpON and the Latch buttons seem to send a signal.
Can this be thought of in the next firmware or is it non midi controls?
I was hoping to catch the BPM’s number without having to “sync”…
Hi monsieurx,
The ability to send and receive hi-res 14-bit knob positions is a beautiful thing. But it eats twice as many CC#s.
For example Mod Wheel sends/receives CC# 1 in standard 7-bit mode, but uses CC#s 1 & 33 in 14-bit mode.
Check out the MIDI CC# assignments on pages 46 & 47.
The [LSB] Least Significant Byte is always 32 higher than the [MSB] Most Significant Byte.
So… there are a lot fewer available CC#s to go around. So… not every button gets its own dedicated CC#.
Thanks for the detailed answer!!! +1
