arp sync Sub 37
Hi everyone!
This is my first post here. Just got my Sub 37 this week. Sounds amazing. :smiley:
I think i have everything setup correct with my DAW,. midi in and out is working good. But when i try to sync the arp, it is sort of syncing to my host, but the timing of every other note is either a bit late or early, (but some are where they should be). Many times i get an odd pause as well, so the next bar will be off.
Is it just me missing something or is the arpeggiator not syncing tight for you as well?
(I made a small test so you could listen to what i get, but i couldn’t upload mp3 or wav here. I will upload elsewhere if i cant figure this out any way,..)
To be sure it wasnt because of some setting in the patches causing this i started with an init preset. Hold 3 midinotes from DAW (in a 16 bar loop). I then put arpeggiator on, and sync on to. Turn rate knob (to what i think is 1/8, but same behavior at any rate) Pattern is in DWN. .
Yes,. i have the latest firmware 1.06
