hello,
just got my fisrt LP and i enjoy it very much.
however, the way the arpegiator works confuses me somehow :
i would like to know if there is a way to play the lfo / arp in free run :
if i sync the LP on midi clock, it will play at the right tempo but it will restart each time i press a key (not lock to the grid), that is sometime usefull, sometimes not good. if i play for example “moroder” kind of arpegio in latch mode, i want the arpegiator to keep perfectly on time even if i press a key forward.
is there any way to select the way lfo and arp triggers? => FREE RUN / TRIGGER.
hello again,
am i wrong configuring the midi sync or the arpegiator ?
is my post unclear? i am not english so maybe this does not mean anything?
could you confirm what i experience with the arpegiator?
Your post makes sense. I think that there is not currently a way to do this, but I suspected from the beginning that it would be a good option. We felt like we had to choose only one way or the other, and we chose the more flexible option.
If it is possible, I would like to add some options to the arpeggiator in the next firmware update, and I will remember this request. It would be good to have the option to choose free-running or triggered, as you suggest. I’ll see what I can do.
For latching arpeggio, this is really crucial to have…
if you are not latching, you can solve this problem by playing legato; it will keep the timing the same. It only re-triggers when all keys are released before the next key is pressed.
