April 2006 Patches
Matrix 12 Eerie lead
Osc: Wave Oct Freq
Osc1: 8.4(232), 2’ , n/a
Osc2: 0, 4’ , 0 (-3)
Osc3: 7.6(210), 4’ , 0
Mixer: Level On/Off
Osc 1: 8(215), On
Osc 2: 6.1(160), On
Osc 3: 2.9(057), On
Ext In: 4.2(106), On
Noise: 5(128), Off
Filter:
Cutoff freq: 2.6 khz, Res: 5.6 (147), Spacing: 0, KB Contr: 6.9 (185),
Mode: LP/LP, Slope: -12db/-12/db, Env amt: -1.2 (-37).
Filter Envelope
Attack: 70mS (163), Decay: 2.5 sec (213), Sustain: 2.9 (059),
Release: 3 sec (222).
Amplitude Envelope
Attack: 3mS (002), Decay: 2.5 mS (015), Sustain: 9 (243),
Release: 1 sec (206).
Mod Wheel Bus:
Source: Tri, Destination: Osc 2, Shaping: On/PGM, Amt: 1.5 (016).
Pedal Bus:
Source: Noise/PGM (Smoothed S/H), Destination: Filter, Shaping: On/PGM,
Amt: 2.6 (049).
LFO: Rate: 5.5 Hz, LFO/Sync: Off/Sync, Release: on, Glide: Off,
Glide Rate: 5 (136).
1>2 Sync: OFF, 3>1 FM: OFF, 3 KB Contr: ON, 3 Freq: HI,
Pitch Bend Amt: Open, Trigger Mode: Single Trigger, KB Mode: Low Note
Priority.
Pot Mapping:
Pot map 1: Src: Filter Res, Dest: Ext Audio In, Direction: Normal,
Amt: 50%.
Pot Map 2: Src; Key Pitch, Dest: Master Volume, Direction: Inverse,
Amt: 25%.
Note: Patch thru reverb (hi-quality spring works best, but any will
work). Patch played w/ mod wheel pushed fully forward produces eerie
one-osc vibrato. If more intense pitch waver needed, bump Mod Wheel
Bus Amt to (018).
Output config: Stereo. Use filter feedback loop.
Pitch Bend not pertinent to patch, as notes work best played stacatto, with
natural release.
Sysex copy will be posted on Squarewave site.
Regards,
Lawrence
Hello,
Quick correction: Cutoff frequency: 2.6khz (196).
Regards,
Lawrence
LWG,
Thanks for this month’s patch. I like the name. Can’t wait to get home and try it out.
