Anyone with a Voyager and Taurus...
Have you hooked them up via Midi yet?
Do you know if, for instance, changing the filter cutoff on the Voyager will cutoff the Taurus as well?
Id love to see some videos to hold me over until I get mine.
Well I don’t think that would work, because I’m pretty sure the Voyager uses two separate CC’s for each pot, however the Taurus values are the same as the Multi-Pedal’s (much higher than 128!) so you never know.
When in doubt, just check the MIDI implementation charts for the Voyager and Taurus 3.
The chart indicates both use the same MIDI assignments for quite a few parameters. For instance filter cutoff for both is MSB 19 LSB 51 and resonance is MSB 21 LSB 53. So filter cutoff will work, along with resonance, filter decay, filter attack, filter envelope amount, and well as many others. I don’t have a set of T3’s to actually try it, but they should play well together.
There is a set of T3’s right now on ebay for BIN of $1995 from audiosyncrazy.
This is not cheering me up fellas.
File uploaded to the T3 microsite: “T3- Voyager Control.jpg”
Should answer all of your questions.
Been playing around with it for about a month now - works great!
  • Greg
Thanks for the replies. It didn’t occur to me to look until AFTER I hit the send button.
Greg, Thanks for your informative documentation. You do a helluva service to us customers.
Would love to hear side by side comparision of Voyager bass versus Taurus bass. With similar waveform and settings of course.
