In the “Implementation” section of this post is all of the midi implementation(including all banks, patch names, course and fine parameters) for the Minimoog Voyager XL!
Benefits: The ability to control all if the Minimoog Moyager XL’s parameters using midi envelopes from within Sonar!(Simultaneously, if you wish!)
How to Assimilate:
- Locate the File ‘Master.ins’ in sonar’s folder. create a back-up copy of this file in a separate location.
- Right-click and open ‘Master.ins’ with notepad.
- Copy the text from the “Implementation” section of this post to the appropriate areas of the ‘Master.ins’ file ie: bank names with bank names, cc’s with other cc’s, patch names with other patch names.), always leaving 1 line between each list. Note: it might be easiest to copy the implementation to a notepad document on your computer first
- Close and save the file
- In Sonar go to Options:Instruments and click the define button in the instruments window.
- Right-click the instrument folder in the file tree on the left and click ‘add instrument’.
- Name it “Minimoog Voyager XL”.
Drag and drop each of the Minimoog Voyager XL patch name lists, Bank name list(you will be asked for a bank number. number banks A-H as 0-9 in corresponding order, C.C.'s list onto your new “Minimoog Voyager XL” instrument definition. NOTE: you will find these lists in the folders of the file tree on the right. - Open the ‘Bank Select Method’ folder from the file tree on the right, and drag and drop the normal bank select method onto the Minimoog Voyager instrument definition on the left.
- Close and Save(if prompted for save, can’t remember?)
- Go to option:instruments and assign your Minimoog Voyager XL to the appropriate midi device and channel(channel 1 is the XL’s default).
Now What?:
Create a midi channel, select the output device to which your XL is connected, select the appropriate channel(1 most likely), choose your XL bank in sonar from the channel, select your XL patch in sonar from the channel, create a sequence using your desired method in sonor, create envelopes if you like: right click in tracks midi lane, create envelop:midi envelope and choose any voyager parameter from a nice long list of them! you can even patch the voyager into your audio interface and monitor through a sonar audio channel, which will also allow you to monitor your sequences through plug-in effects that can also be fully automated.
Sonic Insanity!!
Spectacular automation capabilities!
Implementation:
[Minimoog Voyager XL]
1=Mod Wheel
2=Mod 1
3=LFO Rate
4=Mod 2
5=Glide Rate
6=Mod Wheel Amount
7=Master Volume
8=Pedal/On Amount
9=OSC1 Waveform
10=OSC2 Frequency
11=OSC2 Waveform
12=OSC3 Frequency
13=OSC3 Waveform
14=External Audio Level
15=OSC1 Level
16=OSC2 Level
17=OSC3 Level
18=Noise Level
19=Filter Cutoff
20=Filter Spacing
21=Filter Resonance
22=Filter KB Control Amount
23=Filter Envelope Attack
24=Filter Envelope Decay
25=Filter Envelope Sustain
26=Filter Envelope Release
27=Filter Envelope Amount To Filter
28=Volume Envelope Attack
29=Volume Envelope Decay
30=Volume Envelope Sustain
31=Volume Envelope Release
33=Mod Wheel (FINE)
34=Mod 1 (FINE)
35=LFO Rate (FINE)
36=Mod 2 (FINE)
37=Glide Rate (FINE)
38=Mod Wheel Amount (FINE)
39=Master Volume (FINE)
40=Pedal/On Amount (FINE)
41=OSC1 Waveform (FINE)
42=OSC2 Frequency (FINE)
43=OSC2 Waveform (FINE)
44=OSC3 Frequency (FINE)
45=OSC3 Waveform (FINE)
46=External Audio Level (FINE)
47=OSC1 Level (FINE)
48=OSC2 Level (FINE)
49=OSC3 Level (FINE)
50=Noise Level (FINE)
51=Filter Cutoff (FINE)
52=Filter Spacing (FINE)
53=Filter Resonance (FINE)
54=Filter KB Control Amount (FINE)
55=Filter Envelope Attack (FINE)
56=Filter Envelope Decay (FINE)
57=Filter Envelope Sustain (FINE)
58=Filter Envelope Release (FINE)
59=Filter Envelope Amount To Filter (FINE)
60=Volume Envelope Attack (FINE)
61=Volume Envelope Decay (FINE)
62=Volume Envelope Sustain (FINE)
63=Volume Envelope Release (FINE)
65=Glide Switch
67=LFO Sync Switch
68=Mod Wheel Source
69=Mod Wheel Destination
70=Mod Wheel Shaping
71=Pedal/On Source
72=Pedal/On Destination
73=Pedal/On Shaping
74=OSC.1 Octave
75=OSC.2 Octave
76=OSC.3 Octave
77=1->2 Sync
78=3->1 FM
79=OSC3 KB Control
80=OSC3 Frequency HIgh/Low
81=External Audio Level On/OFF
82=OSC1 On/Off
83=OSC2 On/Off
84=OSC3 On/Off
85=Noise On/Off
86=Filter Mode
87=Envelope Gate Switch
88=Release Switch
89=null
90=null
91=null
92=LFO2 Master Rate
93=LFO2 Master Range
94=LFO2 Master Waveform
95=null
96=null
97=null
98=null
99=null
100=null
101=null
102=LFO2(+)Rate
103=LFO2(+)Range
104=LFO2(+)Clock Division
105=LFO2(+)Waveform
106=LFO2(-)Rate
107=LFO2(-)Range
108=LFO2(-)Clock Division
109=LFO2(-)Waveform
Control=Minimoog Voyager XL
Patch[0]=Minimoog Voyager XL A
Patch[1]=Minimoog Voyager XL B
Patch[2]=Minimoog Voyager XL C
Patch[3]=Minimoog Voyager XL D
Patch[4]=Minimoog Voyager XL E
Patch[5]=Minimoog Voyager XL F
Patch[6]=Minimoog Voyager XL G
Patch[7]=Minimoog Voyager XL H
[Minimoog Voyager XL A]
0=1 Full Saw Bright Bass
1=2 Mod Hyper Sync Lead Sync
2=3 Peaceful 5ths Pads
3=4 Deeeep Sub Bass
4=5 Ringlet Drum Percussion
5=6 Funky Thing Res Lead
6=7 Minor 7th Smooth Lead Interval
7=8 Sea Sick Bass Wobbler Bright Bass
8=9 E Drone w/ Microtones Interval
9=10 FreakFiltMod Synth
10=11 Darkness3!!
11=12 HoloLead velocity Soft Lead
12=13 Bass-sickle Soft Bass
13=14 Drippy Synth
14=15 Sizzle S&H Sweeper Evolution
15=16 Soft and Low Bells
16=17 Sawtooth Seq Sequence
17=18 Smooth Slow Attack Lead Soft Lead
18=19 AM Drum Percussion
19=20 Sleep Little Darling Soft Bass
20=21 Crazy Choir Vox
21=22 Polly Please Pads
22=23 Aint Nobody Clav
23=24 Numbed Res Lead
24=25 Just Blazed Interval
25=26 You Dropped the Bomb Bright Bass
26=27 Dark Sync Lead Sync
27=28 Sunny Chord Interval
28=29 Broken Whimsy Interval
29=30 Swirly Touch Bass Res Bass
30=31 Microtonal Bells Bells
31=32 Underwater Clarinet Soft Lead
32=33 Osc1 Acid OG Res Bass
33=34 Sicko Sweep Evolution
34=35 Softer Keys Piano
35=36 Quartal Pad Pads
36=37 Blipper Sequence
37=38 BubbleVox Vox
38=39 Sync Feeling Sync
39=40 Slow Riser Evolution
40=41 Strange Mod Percussion Percussion
41=42 Alien Pastoral Sound FX
42=43 Big Old Drum Percussion
43=44 Softly Weird Vox
44=45 Wicker Man Evolution
45=46 Rocking Chair Bright Bass
46=47 Min7 Synth Comp Interval
47=48 Ridiculous Funk Res Bass
48=49 Squinky Growth Sound FX
49=50 TouchSurface DubStep Sub Bass
50=51 One Note Riff Interval
51=52 Sub Mod Runner Sub Bass
52=53 Plinking Thing Piano
53=54 Restful Intervals Evolution
54=55 Swarm Weather Evolution
55=56 Quartal Duo Interval
56=57 Sparky Bouncer Motion
57=58 Key Backwater Sound FX
58=59 SugarBlade Bright Lead
59=60 Grinder Drone Evolution
60=61 Filter Osc Percussion 1 Percussion
61=62 Filter Osc Percussion 2 Percussion
62=63 Filter Osc Percussion 3 Percussion
63=64 Filter Osc Percussion 4 Percussion
64=65 Bass Sweep Bright Bass
65=66 ModVox Vox
66=67 Squiggler Sound FX
67=68 Sweep Thing Evolution
68=69 Percussted Percussion
69=70 Cop That S**t Bright Bass
70=71 3 Times Narrower Bright Bass
71=72 Subtle 5th Bass Bright Bass
72=73 Tuned Bongos Sequence
73=74 Simple BP & Saw Res Bass
74=75 Dub the Pad Sequence
75=76 Sync Pad Sync
76=77 1Pole Dub PadAttack Bright Bass
77=78 Wild Style Res Lead
78=79 Moped Lead Res Lead
79=80 Ride it out Man Bright Bass
80=81 Electro Arp Sequence
81=82 Obersync Sync
82=83 Space Funk Synth
83=84 Textures Bass Res Bass
84=85 Computer Love Res Bass
85=86 Zapp Bass Bright Bass
86=87 Lodidodi Bass Res Bass
87=88 Lodidodi Lead Soft Lead
88=89 Minor Trigger Interval
89=90 Knock Bass Soft Bass
90=91 Classic Lead W/Mod Sting Bright Lead
91=92 BurninBass Sub Bass
92=93 Space Opera Synth
93=94 Dark and Wobbly Bass Soft Bass
94=95 Velocity Detune Soft Lead
95=96 Seq Sync 8-bit Sequence
96=97 Nasty FMSync Bright Lead
97=98 Blue Tube Bass Soft Bass
98=99 Jah David Dub Bass Sub Bass
99=100 AdamSyncLead Sync
100=101 Velocity Seeker Sequence
101=102 Synth Bowed String Strings
102=103 3 Octaves Bright Bass
103=104 1-Pole Madness Bright Bass
104=105 Stab Bass Res Bass
105=106 80s Obie Lead Bright Lead
106=107 Slow Attack PitchedNoise Sound FX
107=108 Alien Congas Percussion
108=109 Helium Growl Lead Bright Lead
109=110 1Pole Sweep Bright Bass
110=111 Dark Marimba Sequence
111=112 Bi-Polar Res Lead
112=113 Bandpass Bass Res Bass
113=114 S&H Wave Bass Sweep Res Bass
114=115 Pluckered Lead Bright Lead
115=116 PWM Lead Osc1 Mod Pan Bright Lead
116=117 AdamLead! Sync
117=118 Mod Wheel Rising Sound Evolution
118=119 FM Touch Percussion
119=120 StrangeThing Sound FX
120=121 Touch Seeker Percussion
121=122 50s Computer Meltdown Sound FX
122=123 Glitch Crickets Sound FX
123=124 AdamCoolDron Evolution
124=125 AdamSmp&Hold Synth
125=126 TouchPadTrigStockhausen Sound FX
126=127 The Falling Sound Sound FX
127=128 Wave Echo Rhythm Motion
[Minimoog Voyager XL B]
0=1 Tasty Moog Bass Res Bass
1=2 Techno Tuvans Vox
2=3 Electric Panning Keys Piano
3=4 A Minor Story Panned Motion
4=5 Solar Lead Soft Lead
5=6 Membrane Mallet Percussion
6=7 Acid Mod Grind Res Bass
7=8 MajorWerk Interval
8=9 Wo ist der Sinus? Percussion
9=10 Lead or Follow Res Lead
10=11 Really Heavy Bright Lead
11=12 PWM in the Bass Soft Bass
12=13 Orgone Box Res Lead
13=14 Mellow Brass Bass Brass
14=15 Soundscape Shifter Evolution
15=16 8-Bit Video Game Sound FX
16=17 Wormy Lead Res Lead
17=18 Clean Machine Synth
18=19 Sync or Swim Sync
19=20 Velocity Temple Bells Percussion
20=21 Mod Wheel Buzz Synth
21=22 Floating Mod Sync Guitar Inst
22=23 Tiny W/O Mod Percussion
23=24 Big Boy Bright Bass
24=25 High as a Kite Bright Lead
25=26 Running Drone Motion
26=27 Subaqueous Lead Soft Lead
27=28 Too Low Sub Bass
28=29 Slow Wave Dancer Motion
29=30 The Cheez Res Lead
30=31 Slow Deep High Evolution
31=32 Rezzy Fifths Interval
32=33 Glassy Mod Sparkle Piano
33=34Rezzy Manic Lead Res Lead
34=35 Crispy Evolution
35=36 Controller Bass Res Bass
36=37 Overcast Pad
37=38 Really Weird Drum Percussion
38=39 Mod Heavy Bright Lead
39=40 Slow Impression Evolution
40=41 Rubber Flute Damage Inst
41=42 Wormy Bass Res Lead
42=43 Velocity Decay Piano
43=44 Dark Electricity Evolution
44=45 Soft Wobbly Lead Soft Lead
45=46 Random Pan Pad
46=47 Plucky Lead Classic
47=48 A Touch of Growl Bass Soft Bass
48=49 Abrasive Wheel Bright Lead
49=50 Booty Drop Sub Bass
50=51FilterOrgNasty(Wheel Up) Organ
51=52 FM ClunkBass Bright Bass
52=53 Kick in the Sub Percussion
53=54 DX Bass Bite Res Bass
54=55 Tiny Sparkle Mod Lead Bright Lead
55=56 Soft Velo Harmonics
56=57 Stringy Bite Soft Lead
57=58 Teknomancer minor3rd Interval
58=59 Thicka Shred Bright Lead
59=60 Skinny but Fat Bright Bass
60=61 Warm Keys Piano
61=62 Rock You Do Bright Lead
62=63 Free Theme Soft Lead
63=64 A Basic Punchy Sucka Sequence
64=65 The One Bright Bass
65=66 New Sync Mod Solo Sync
66=67 Buzzed Pluck Lead Synth
67=68 Truth In You Theme Soft Lead
68=69 Tonto Bass Bright Bass
69=70 Tonto Lead Soft Lead
70=71 BothHi&Lo(RadioTP) Bright Lead
71=72 Fifths of Fury Interval
72=73 BorisThe Bass Spider Bright Bass
73=74 Lo, He Plucks it Well Interval
74=75 Interval Lead Soft Lead
75=76 Wind Me Up Please Evolution
76=77 LoDownSquare Boy Soft Lead
77=78 My Days Bass Soft Bass
78=79 My Days Sequence 2 Sequence
79=80 My Days Theme 2 Soft Lead
80=81 Press 2 Glide Theremin Soft Lead
81=82 Lip Buzz Synth
82=83 Organish Lead Organ
83=84 Mosquito Lead Sound FX
84=85 Sweeping Bassy Fifths Evolution
85=86 Velocity Bright Lead
86=87 Velocity Res Lead Soft Lead
87=88 Weasel Goes Pop Bright Lead
88=89 Expressive Soft Lead
89=90 Plucked and Pulsed Soft Lead
90=91 VelociMoog Res Bass
91=92 The Clock Strikes 12 Percussion
92=93 High Velo Lead Soft Lead
93=94 Get Fifthy Interval
94=95 Pulsing Syncer Sync
95=96 Cluster Drum Percussion
96=97 Skinny Keys Piano
97=98 Treasure Lead Soft Lead
98=99 Detuned Vox Soft Lead
99=100 Velocity Res Bass
100=101 Sub Teach Sub Bass
101=102 Slow Mod Panning Lead Soft Lead
102=103 Mix Hog Bass Bright Bass
103=104 Pastoral Soft Lead
104=105 Bright Pluck Sync
105=106 Space Strings
106=107 Space Whistle Bright Lead
107=108 Classic Lead Bright Lead
108=109 Bright One Bright Lead
109=110 Zapper Sound FX
110=111 Sweep Evolution
111=112 This Story Theme Soft Lead
112=113 This Story Seq 2 Sequence
113=114 This Story Theme 2 Sync
114=115 This Story Bass Soft Bass
115=116 Wet’nWobbly PopTop Bright Lead
116=117 Metal Junk Percussion
117=118 DoubleTheremin Soft Lead
118=119 Slightly Messy Noise
119=120 Sync Mini(AT) Sync
120=121 DozingInThe AfterBuzz Soft Lead
121=122 The Lair of Doctor Vile Sound FX
122=123 Don*t Forget to Sweep Sound FX
123=124 Free Noise
124=125 Disaster Sync
125=126 My Broken Shortwave Sound FX
126=127 Panning Growth Evolution
127=128 Stuttering Evolution Motion
[Minimoog Voyager XL C]
0=1 Speaker Danger Bass
1=2 SimplySmooth
2=3 Mod Wheel Dive Bomb
3=4 Climb
4=5 Squeaky Bells
5=6 Subtle 5ths
6=7 Just the Sub
7=8 Velocity Growl
8=9 Filtroid Damage
9=10 Black Market
10=11 Chinease
11=12 Yammerer
12=13 Fat Drums
13=14 In The Net
14=15 4ths Synth
15=16 Nige ClassicBass
16=17 Seq. w/ Mod Wheel Ring
17=18 Oboe&Bassoon
18=19 Bass Sweep +Grungy Wheel
19=20 Sci-Fi Honky-Tonk
20=21 Can U Solo
21=22 Tiny Touch
22=23 Sweet but Weird
23=24 Endless Moog
24=25 Queen of Chi
25=26 Old Castle
26=27 Citadel Bass
27=28 HPcompressedClav
28=29 Mod WheelTheremin
29=30 Hard Attack
30=31 Talk 2 Me Guitar
31=32 Grits and Eggs Bass
32=33 Jan 7 Days
33=34 Diet of Worms
34=35 Wonder Mini
35=36 Dr Who Bass
36=37 Rob Progs Out
37=38 Get The Funk
38=39 Horror Intro
39=40 Metallic Percussion
40=41 Mini Prog Lead
41=42 Pedal Power
42=43 Good oldFaithful
43=44 Bowed Shifter
44=45 4ever Return
45=46 Significant Sonics
46=47 Rose Lead
47=48 Bell Drops
48=49 Tony Moog
49=50 Velocity Felicity
50=51 Mod Lead
51=52 Oscillator Mayhem
52=53 Square Lead
53=54 In Yer Face
54=55 BrightPluckyLead
55=56 My Brass Bed
56=57 FM 5ths
57=58 BoogieBass
58=59 Threw a Party
59=60 L’i’l 5th Wheel Echo
60=61 Snappy
61=62 I’m Large
62=63 Trick of theTail
63=64 Nasty Drums
64=65 Distant Cousins
65=66 Chick Lead
66=67 Big Punch Sub
67=68 S and H Cluster
68=69 Weird Pizzicato
69=70 2 Pole Bass
70=71 Asao’s Cakewalk
71=72 Accordion
72=73 Bake ‘n’ Fry
73=74 MoogPeow C
74=75 Basso Flabulo
75=76 Slow Attack
76=77 Rubbery Bass Weird Wheel
77=78 4ths Random Trill Wheel
78=79 Duke
79=80 Walk away
80=81 SequenceYourThirst
81=82 Picture This
82=83 Panning Keys
83=84 Birdy Bass
84=85 Job Done
85=86 Analog Gongs
86=87 No Rest
87=88 Owwww Bass
88=89 Mod my Filter!
89=90 Magic Man
90=91 Cymbolic
91=92 Bomb-Basstic
92=93 Organ '66
93=94 80’s Seq
94=95 Bass Drum w/Wheel FM
95=96 Yc45 RM
96=97 Pre-Mental Tension
97=98 Strange Growth
98=99 Katy’s Moog Bass
99=100 Get the Kleenex
100=101 Behave You Hussy
101=102 Thumping E-Bass
102=103 Minimoog 70’s
103=104 Yowsa Bass
104=105 JP Lead 1
105=106 Weird Bells
106=107 Finsbury Park
107=108 Long Slow Growth
108=109 Really GrossMod Wheel
109=110 Mod Sweeper Bass
110=111 Little Mooger
111=112 Lucky Man
112=113 Dripsodic
113=114 How Deep
114=115 Sunrise
115=116 Over Zealous
116=117 Slow Stereo Square Bass
117=118 Minotaur
118=119 Lava Surfing
119=120 Chalameau Bass
120=121 From The Beginning
121=122 Wheel Sync Runner
122=123 Random Pan Triangle
123=124 Emerson Saw
124=125 Velocity Square Drumz
125=126 GentleRunner
126=127 Yeeeaaaayy
127=128 Big Bang
[Minimoog Voyager XL D]
0=1 Big Detuned Bass
1=2 Tweezy Grunge
2=3 Glide Lead
3=4 Stringy
4=5 Bernie Down Da House
5=6 Warm Wow Bass
6=7 Electro Marimba
7=8 Mellowness
8=9 Rude Sync Lead
9=10 Submarine Landscape
10=11 Any Color Lead
11=12 The Way We Feel
12=13 Bernie’s #01Woo~man
13=14 Outer LimitsClav
14=15 Squelcher
15=16 Man Child Lead
16=17 Destructo Drum
17=18 Organ Transplant
18=19 Sci-fi Wiggler
19=20 Glass Backwards
20=21 Lead Runner
21=22 Snappy Bass w/ Sub
22=23 Waveform Dance
23=24 Trumpet
24=25 Mod Wheel Pedal Steel
25=26 Nukular Canine
26=27 Mod Wheel Whistler
27=28 Space BellDrum
28=29 Cars Intro (Mod Wheel)
29=30 Grinder Lead
30=31 Strange Bass
31=32 PurpleJude
32=33 Deep Space Tones
33=34 Squeaker Lead
34=35 Bow Wow Bass
35=36 Mellow and Horn-like
36=37 One Pole Bass
37=38 Old Movie
38=39 Fat PWM Bass
39=40 Mod Wheel Buzz Saw
40=41 Plucked Whistler
41=42 Rubbery Keys
42=43 Square Glider
43=44 Alien Insects
44=45 Mongo Res Lead
45=46 Ripper Bass
46=47 Duke it Out Lead
47=48 wooOOOOooow
48=49 Eccentric Orbit
49=50 Sawtooth Lead
50=51 Kalimboid
51=52 Crinkly lead
52=53 Kick Factory (wheel up)
53=54 ‘Lectrafunk Bass
54=55 Slow and Shifty
55=56 Bloom Bass
56=57 Dynamic Buzz
57=58 Vocal PulseMod
58=59 Pipes&wheels
59=60 Impact Bass
60=61 Mumbler Lead
61=62 A Drone
62=63 Our Daily Lead
63=64 Instability
64=65 Glocken
65=66 Bright and Rezzy
66=67 Two Pole Growler
67=68 Future Lead
68=69 Bass Drops
69=70 Plucky Lead
70=71 Basswerk
71=72 Mod WheelHowler
72=73 Tomitavox
73=74 Analog Shimmer
74=75 SoftnHollow
75=76 Numanesque Lead
76=77 PluckyBassy
77=78 Metal Sizzle Percussion
78=79 Chordal Mod Surprise
79=80 One Pole Lead
80=81 SubterraneanSquare
81=82 Enoesquepad
82=83 Clustered
83=84 Tin on Wheels
84=85 Atomic Geetah
85=86 Radio Lead
86=87 Dirty Wheels
87=88 Dingy*drops?
88=89 AM Radio Strings
89=90 Rhythmic Harmonics
90=91 WowowoWheel
91=92 Knocking Bass
92=93 Digifone
93=94 Growing Shifter
94=95 Sky Saw Sync
95=96 Pulsing Bass
96=97 Water Wheels
97=98 Riser
98=99 Electrozap Bass
99=100 AlienKalimba
100=101 Sub-Growl
101=102 Guess Woo? Yoo!
102=103 Da’ Bass Drum
103=104 Little Ringer
104=105 TDarpeggio
105=106 Hornz
106=107 Rezzorama
107=108 Marimboid
108=109 Slow Sweep Runner
109=110 Dark PWM Bass
110=111 Panning Chimes
111=112 Fat Skinny Bass
112=113 70s Leadz
113=114 Slow Pitch Slider
114=115 Insyncerator
115=116 Hobbes Knobbs
116=117 String Thing
117=118 Bwa Machine
118=119 Flashlite 2004+
119=120 Velocity Blipz
120=121 Hairball Bass
121=122 TouchActive FX
122=123 Sub Sub Bass
123=124 Kaotik (wheelup)
124=125 Harpsimoog
125=126 Sync Drum
126=127 Cottonmouth Lead
127=128 On the Horizon
[Minimoog Voyager XL E]
0=1 RUNNING BASS
1=2 BIG SEQUENCE BASS
2=3 CLASSIC BASS
3=4 BRAIN SALAD BASS
4=5 RUBBER BAND BASS
5=6 CHAMELEON BASS
6=7 FINGERBASS
7=8 XBASS
8=9 STABNAMMIT
9=10 FAT FILTER
10=11 WRECKBASS
11=12 METAL STRINGBASS
12=13 DOPE BASS
13=14 CATHERINE OF ARAGON
14=15 ROGER 0 RIP
15=16 HELLA BASS
16=17 RUB-A-DUB BASS
17=18 NEW WAVE BASS
18=19 CHEEGLE SYNC
19=20 SKYCHURCH BASS ESC
20=21 DARK VOICE BASS
21=22 BASS JONES
22=23 1996
23=24 CLAV BASS
24=25 BROKE LOW BASS
25=26 BURNS FOR BASS
26=27 ALL NIGHT BASS
27=28 ACIDIC BASS
28=29 FUNKY BASS
29=30 TUBE BASS
30=31 TIGHT BASS
31=32 SYNCROWL
32=33 CUTIE PIE BASS
33=34 SMOOTH BITE
34=35 SLOW SWEEP BASS
35=36 SQUARE FACE BASS
36=37 AQUATARK LEAD
37=38 HELLO
38=39 LEAD DOG
39=40 JAZZBO FLUTE
40=41 DIG-DUG
41=42 HEALTHY LEAD
42=43 DONIMATRIX
43=44 FIFTH SYNC LEAD
44=45 DPGLEAD
45=46 WHAM BAMM…
46=47 OLD MINI
47=48 SCIENCE
48=49 MOSHI MOSHI
49=50 ELO SWEEP
50=51 TRILOGIC
51=52 CELLOGY
52=53 DR.MADNESS
53=54 CALLN OUTNAMZ
54=55 CHORUSED LEAD
55=56 COME BACK LEAD
56=57 KEEZER LEAD
57=58 TIGERMOUNT
58=59 PSYCHEDELIC FICTION
59=60 REPEATER
60=61 FREDWRECK BAZ
61=62 ZAZA’S MATH
62=63 TRIUMVIRATE
63=64 GAMES W/O FRONTIERS
64=65 LEAD CLICK
65=66 BEAUTIFUL 1
66=67 COMPTON LEAD
67=68 FM-SYNC
68=69 SOULFUL LEAD
69=70 SKYCHURCH DULCIMER
70=71 SINGING LEAD
71=72 DIGITAL BUDDAH
72=73 ORGAN REGION
73=74 SKINNY2
74=75 FL’s LEAD
75=76 SUNSHINE LEAD
76=77 BRASSED OFF
77=78 DIRTY LEAD
78=79 HEAD DUCK*
79=80 MULTI- LEAD
80=81 IM IN LOVE
81=82 AMERICAN DREAM
82=83 HIPASSCLAV
83=84 UGLY *%!#’ FACE
84=85 ODDS
85=86 SHAYS DANCE
86=87 STAG RADI0
87=88 SKYCHURCH EVOLUTION
88=89 RELAXATION DRONE
89=90 DROP WHEEL PUSH
90=91 SHOCK COIL
91=92 SIZZLE SWEEP
92=93 LONELY TRAINWHISTLE
93=94 ALIEN STUTTER
94=95 MINOR 7TH AND 5TH
95=96 PUSH->CLOSEDLIFT->OPEN
96=97 MY FLOWBEE
97=98 WIZARD OF MONTARA
98=99 DENTISTRY
99=100 CHADZARSE
100=101 TOUCHPAD FX l
101=102 MOD WHEEL BUBBLER
102=103 PANNING AAOW
103=104 R2 CPU
104=105 FLANGE SCRAPE
105=106 THE LIGHT
106=107 DARKNESS
107=108 ASHES TO ASHES
108=109 ARP MOD PAN
109=110 CLAV DELAY
110=111 SWITCHED ON!
111=112 LITTLE BELL
112=113 TWINK BLIPS
113=114 BIG LOW DRUM
114=115 CIRCUIT DRUM
115=116 NOISY PERCUSSION
116=117 REZ DRUM
117=118 DUB STYLEY
118=119 DRUM FROM MARS
119=120 XFITZ~~~
120=121 TWISTER PERCUSSION
121=122 POPTART DRUM
122=123 TEKKIK``
123=124 ELECTRO PERCUSSION
124=125 MIAMI DROP BASS
125=126 SKYCHURCHjlTOUCHPADRUM
126=127 SHARDS
127=128 GALACTIC DROPS
[Minimoog Voyager XL F]
0=1 CLASSIC MINI
1=2 HAMMER’S PULSE
2=3 GEORGE’S NARROW PULSE
3=4 SOFT MINI
4=5 STEVE’S WINWOOD
5=6 JOE’S 2600
6=7 T. WOLF’S GUITAR
7=8 CHICK’S FIVE
8=9 HEAVY S+H
9=10 CLASSIC SAW
10=11 WISH YOU WERE HERE!
11=12 HERBY’S D6
12=13 JAN’S HAMMER
13=14 HIP HOP B3
14=15 FIRST SEVEN NIGHTS
15=16 FIRST NIGHT SYNCED
16=17 MOOG HARP
17=18 RICK’S CATHERINE
18=19 BILLY’S DRUMMW+PEDAMOUNT
19=20 MOOG BASS
20=21 THE FAT ONE
21=22 PUNCHER
22=23 LIKE CHILDREN
23=24 PLUCK IT !
24=25 I AM THE BASS
25=26 THE BIG ONE
26=27 FRETLESS
27=28 BACK TO THE ROOTS
28=29 FUNK IT
29=30 FUNKY CAT
30=31 GETTING MEAN
31=32 GETTING MEANAGAIN
32=33 WIRED
33=34 JOE PASS WAS HERE
34=35 WIRED BASS
35=36 CHICK’S ROM WARRIOR
36=37 CHICK’S OBOE
37=38 ANOTHER HAMMER
38=39 JAN’S KEYCLICKER
39=40 RESONANT PULSE
40=41 TAKE FIVE
41=42 HAMMER FLUTE
42=43 I AM THE ONE
43=44 THEREMINE?
44=45 SPACY
45=46 JUST RESONANCE!
46=47 BULLETS?
47=48 B3 SOLO
48=49 TIME FOR SURFIN’
49=50 PANIC?
50=51 V BASS
51=52 STOMPING MM TRY MODWHEEL
52=53 GET SYNCED! TRY MODWHEEL
53=54 FLAGEOLET? TRY VELOCITY
54=55 SYNCED HARP TRY VELOCITY
55=56 CHENG TRY VELOCITY
56=57 SYNCED GUITAR
57=58 MYSTERIOUS FLUTE
58=59 RUDI’S SPACYPHASER
59=60 SOME MODULATION?
60=61 DOUBLE-BASS
61=62 THE DUKE
62=63 S+H SWEEPER TRY MODWHEEL
63=64 MOOG AND THEMECHANICS
64=65 SQUAREDANCE
65=66 TECH NO!
66=67 SOME RING- MODULATION?
67=68 I LIKE S+H!
68=69 SPACE INVADER
69=70 BASS BOOSTERTRY M2PEDAL
70=71 FLANGING VOYAGER
71=72 SQUARY
72=73 SYNC 5
73=74 GETTING NASTY
74=75 JAN AND JEFFARE BACK
75=76 BUBBLEBASS
76=77 RHYTHM AND MOOG
77=78 FROM A DISTANCE
78=79 AGAIN: TECH NO!
79=80 TYPICAL MOOGBASS 1:1MINI
80=81 JAN HAMMER BASS 1:1MINI
81=82 RECTANGULAR BASS 1:1MINI
82=83 RIPPER BASS
83=84 FAT BASS
84=85 BLOCKBUSTER
85=86 CLASSIC LEAD
86=87 ARE YOU SQUARED?
87=88 VELOCITY MODSAW
88=89 BATTLE OF EPPINGFOREST
89=90 POPCORN
90=91 HELLO KEITH
91=92 ELP TRILOGY
92=93 AQUATARKUS
93=94 MOOG PERCUSSION
94=95 BUZZY BASS
95=96 VULGAR BASS
96=97 HIP AND HOP
97=98 ANCIENT BELL
98=99 BIG IN THE 80S
99=100 REMINDER OF JASPER
100=101 ALIENATTACK TRY MODWHEEL
101=102 ANYONE OUT THERE?
102=103 SQUEEZE IT! TRY MODWHEEL
103=104 HELLO LYLE!
104=105 JAN MEETS AL
105=106 HAMMOND B5
106=107 INDUSTRIAL
107=108 MOOG 55
108=109 DEFUNKED DX7 RHODES
109=110 ROTAROTATING
110=111 NO MUTES!
111=112 EARTH WIND AND BRASS
112=113 HIP HOP, BRASS
113=114 TECHNO POWERSTATION
114=115 E-DRUM
115=116 DREAMING TECHNO
116=117 BIG BRASS
117=118 TOTAHORNS
118=119 SLOW BRASS
119=120 TRUMPET
120=121 HELLO MILES
121=122 PLAY A RHYTHM + MW
122=123 HI EDGAR!
123=124 SAGA SWEEPER
124=125 OFFRAMP
125=126 RHYTHM AND MOOG
126=127 KNOCKING ON THE MINI
127=128 SIMMONS DRUM
[Minimoog Voyager XL G]
0=1 Oooof
1=2 Trogg
2=3 Classic
3=4 Old Noise
4=5 Mellow Lead
5=6 Theremini
6=7 Smoosh
7=8 Dee-Dah
8=9 Spot Lite
9=10 Cop Show
10=11 1976
11=12 Clockwork
12=13 Mars
13=14 Clang
14=15 Ton
15=16 Popcorn
16=17 Welcome
17=18 Bold Bass
18=19 Frank
19=20 Triggy
20=21 Fusion
21=22 Stunner
22=23 School Bass
23=24 Fozzy
24=25 Groover
25=26 Growth
26=27 Punch
27=28 Elastic
28=29 Biplane Modwheel
29=30 1968
30=31 Solar
31=32 Troll
32=33 Runner
33=34 Hard
34=35 Flaut
35=36 Solid
36=37 Stinger
37=38 Boca
38=39 Girth
39=40 Pomp
40=41 Cutter
41=42 Parsec
42=43 Baa Baa
43=44 Noid
44=45 Perco
45=46 Zinger
46=47 1969
47=48 Oh-Wa
48=49 Slider
49=50 Fuzzy
50=51 Source
51=52 Wonder
52=53 Spider
53=54 Slick
54=55 Glom
55=56 Tubby Bass
56=57 Donefor
57=58 Clippers
58=59 Scoop
59=60 Electro
60=61 Bug Drops
61=62 Sub Kick
62=63 Perc.1
63=64 Hhat
64=65 Syntom
65=66 Preset Default PROG
66=67 Preset Default PROG
67=68 Preset Default PROG
68=69 Preset Default PROG
69=70 Preset Default PROG
70=71 Preset Default PROG
71=72 Preset Default PROG
72=73 Preset Default PROG
73=74 Preset Default PROG
74=75 Preset Default PROG
75=76 Preset Default PROG
76=77 Preset Default PROG
77=78 Preset Default PROG
78=79 Preset Default PROG
79=80 Preset Default PROG
80=81 Preset Default PROG
81=82 Preset Default PROG
82=83 Preset Default PROG
83=84 Preset Default PROG
84=85 Preset Default PROG
85=86 Preset Default PROG
86=87 Preset Default PROG
87=88 Preset Default PROG
88=89 Preset Default PROG
89=90 Preset Default PROG
90=91 Preset Default PROG
91=92 Preset Default PROG
92=93 Preset Default PROG
93=94 Preset Default PROG
94=95 Preset Default PROG
95=96 Preset Default PROG
96=97 Preset Default PROG
97=98 Preset Default PROG
98=99 Preset Default PROG
99=100 Preset Default PROG
100=101 Preset Default PROG
101=102 Preset Default PROG
102=103 Preset Default PROG
103=104 Preset Default PROG
104=105 Preset Default PROG
105=106 Preset Default PROG
106=107 Preset Default PROG
107=108 Preset Default PROG
108=109 Preset Default PROG
109=110 Preset Default PROG
110=111 Preset Default PROG
111=112 Preset Default PROG
112=113 Preset Default PROG
113=114 Preset Default PROG
114=115 Preset Default PROG
115=116 Preset Default PROG
116=117 Preset Default PROG
117=118 Preset Default PROG
118=119 Preset Default PROG
119=120 Preset Default PROG
120=121 Preset Default PROG
121=122 Preset Default PROG
122=123 Preset Default PROG
123=124 Preset Default PROG
124=125 Preset Default PROG
125=126 Preset Default PROG
126=127 Preset Default PROG
127=128 Preset Default PROG
[Minimoog Voyager XL H]
0=1 I’m Ba-aack!!
1=2 Chiffy Lead
2=3 Brassy Lead
3=4 Robo Vox
4=5 Growing Lead
5=6 X-tra low Bass
6=7 Mellow Hammer
7=8 Hollow Bass
8=9 Brain Salad Buzz
9=10 Gurglet
10=11 Cycler mod (wheel up)
11=12 Wetness (wheel up)
12=13 Animated (wheel up)
13=14 He was lucky
14=15 Tympanic membrane
15=16 Kinda saxy
16=17 Analog Daze
17=18 Heartbeat
18=19 Electric Room
19=20 Monica
20=21 Wheel Bass
21=22 Vowel Bass (wheel up)
22=23 Slippery Lead
23=24 Classic Ripper
24=25 Toad Bass
25=26 Velocity Bass
26=27 Velowave Bass
27=28 Funny Vox
28=29 Minor Glider
29=30 Prog Lead
30=31 Forever Lead
31=32 Here it comes
32=33 Panning Throbber
33=34 Zappy Bass
34=35 Classic Sweeper
35=36 Touchpad sync
36=37 First Love
37=38 Clearly fuzzy
38=39 Fond Memories
39=40 Flyin’ fingers
40=41 Worms of funk
41=42 Tremowah Bass
42=43 Welcoming machine
43=44 Touchpad horn
44=45 Still fun (wheel up)
45=46 Subfood Bass
46=47 Firm bottom
47=48 Lunar News (wheel up)
48=49 Seafoam (wheel up)
49=50 Wheel talker
50=51 Living Bass
51=52 Pucker up
52=53 Lil’ delay
53=54 Utopian Lead
54=55 Bouncer (wheel up)
55=56 Stereo Zaps
56=57 In the pocket
57=58 Going Baroque
58=59 Flutey
59=60 Relaxed Bass
60=61 Mystery metal
61=62 “B” drone jam
62=63 No knives please
63=64 Topographic melodies
64=65 Familiar growl
65=66 Make it sing
66=67 For Ripley
67=68 Other life
68=69 Epiphany
69=70 Crop circle delivery
70=71 Swamp life
71=72 Spartacus
72=73 Horn of Mythos
73=74 Call of the Gearpig
74=75 Soft as I remember
75=76 Stereo S&H (wheel up)
76=77 Harmonized (wheel up)
77=78 Sasquatch speaks up
78=79 Bo
79=80 Some funk for ya’
80=81 Bubbly Lead
81=82 Synthworld
82=83 Aleatoric
83=84 Wheel chorusLead
84=85 Glass Temple
85=86 Repeater Bass
86=87 Electro Kid
87=88 Fuzzy Lead
88=89 Catherine of Aragon
89=90 Catherine Howard
90=91 Anne Boleyn Bass
91=92 Anne Boleyn Lead
92=93 Raw & melodic
93=94 Sweepy Bass
94=95 Green Fog
95=96 Wrong Crypt
96=97 Just the harmonics
97=98 Thematic
98=99 Plucky Bass
99=100 Bright Bass
100=101 Tubby Bass
101=102 Alien Metal
102=103 NOT Unplugged
103=104 Bass Phenomena
104=105 Reedy Bass (use wheel)
105=106 Dramatic Entrance
106=107 Flying Toy
107=108 Alley Cat
108=109 Speedway
109=110 Call the plumber
110=111 Sweet Thing
111=112 Tribal
112=113 Plucked Lead
113=114 Hollow Fuzzytone
114=115 Sizzle Bass
115=116 Fly by
116=117 Short lived
117=118 What the…
118=119 Harpsinotes
119=120 Not small
120=121 Tiny flute
121=122 Cosmic chatter
122=123 Ridin’ the storm out
123=124 Large fifths
124=125 Fanfare
125=126 Synergistic
126=127 Bass for E. Vonallen
127=128 Windy night
[No Drums]
