I am just courious, but does anyone here use a Modular synthesizer as either you main instrument or with other keyboards. Be it a vintage Moog Modular or a brand new one like a synthesizers.com. ![]()
I’m building a MOTM modular. Ask me again in about six months, though, as I just got my first modules.
Seth
Good Luck!
Enjoy & let us know how it goes !!
I’m using the Voyager in connection with my modular set up: Doepfer, Analogue Solutions, and Wiard modules. As it’s all 1V/Oct, there’s no problem with connectivity. The wonderful thing about modulars is that there is no limit to the modulation routing. (Want to experiment with outputs > inputs? Oscs modulating themselves? No problem!). The downside is no patch memories, and sometimes no limitations leads to blank tape syndrome…
-andrew bunny
I have a Voyager+251,351 and a MOTM/Blacet system.
So far for MOTM it’s
1 VCO (with 2 ultras VCO’s on order),
1 filter(with 3 more on order),
2 EG’s, 2 VCA’s, CV mixer, Mult, LFO.
Blacet(soon to be converted to MOTM format)
A Mini-Wave,
Binary Zone,
Time Machine
I/O
2 Dark Star Chaos
Ken Stone home made
Synthacon VCF
Just getting deeper into the modular stuff. It all works great with the Voyager.
Hi sir_dss,
How would you rate each of those components with your voyager. Also, don’t you need two Time Machines with the Voyager for it to be in stereo? Which module do you find best? Worst? Best value, etc. I would love to hear more. I also have the 251 and 351 w/ my Voyager and am looking to expand.
Things have been a bit busy but…
The Blacet Binary Zone
Makes for a wonderful simple sequencer with gate outputs. Create some sort of melody/sequence and trigger the Moog’s envelope with it.
I love to use the Voyager’s touchpad to control the Delay time on the Blacet Time Machine with the 351. I also have a MF-104. So the X controls the TM’s delay, the Y controls the 104’s delay and A controls both of the feedback amounts from the delays.
The Dark Star is just audio violence. And not in production anymore.
Blacet Miniwave:
Works great as an extra VCO when run into the Voyager’s Ext.In. All sorts of digital waveforms. Don’t be scared about the digital term in this context it works great to BLEND with other analog VCO and through the Voyager’s VCF. And when driven with a LFO you get all sorts of strange waveform patterns like the “Batman wave” or the “Skyscraper wave” that sound pretty different/awesome" As a quantizer it really helps the Binary Zone so the BZ stays in standard pitch. No microtonal sequences, that way you can play along with these sequences with another synth.
MOTM MODULES just rule.
sir_dss,
I have just started a blacet modular with a miniwave, precisely for the reason in your response. So, as it has not arrived yet, pray tell how you connect it to the voyager. I am assuming that you use another saw osc (driven by the voyager’s pitch out) into the miniwave? Or do you just send the voyager’s pre-filter mix?
ta
suth.
p.s. I use my voyager in conjuntion with doepfer and analogue sys modules (plus one or two CVable pedals) all the time. I really wish the vx351 allowed you to tap out the individual oscillator signals, though, as this would make the voyager a true modular monster ![]()
I want to get started in building modular unit as well. sir_dss would you recommend the Dark Star? I have never played one but I like your description of audio violence. I sort of want to add the dimension to my setup which includes a Source and various EMU gear, but I find that wild in your face sound missing.
suthnear
I do the the MW pre mixer using the effects loop. Use the SEND side of the Y cable to the input of the MW into your moduals VCF>VCA or whatever you use. Triangle waves are the best but you can get some great messed up sounds with other waveforms. I like to use a seperate VCO like my MOTM 300 to drive the MW so I can still use the MMV. You can also send the left output(unless you run the MMV in stereo) to the MW and send it back to the EXT. IN on the MMV for an extra voice. It won’t be as clean but for what I use it for it’s alright.
For MW LFO modulation, I send the LFO output from the VX-351 to the MW IN then go to the MMV’s FILTER, WAVE, VOLUME inputs on the back panel ot the MMV.
I’ve actually bought the expander for the MW so I now can have 10 diffrent eproms! It’s not done yet but take a look.
http://www.hylander.com/miniwave.html
http://wiseguysynth.com/larry/mw2090/cv-expand/complete_front.jpg
gd
The DSC does rule but out of production. But don’t worry the best part of the DSC is controling the Noise Clock. So you can move from a tide of white hiss to a drop of click with a turn of a knob. Ken Stone has a pcb that seems easy to build that is just the noise clock.
It’s under the sections “Modules” then under “Digital Noise”. I don’t know if if it work with the EMU, Source set up unless it had quite a bit of CV in’s and outs.
later
MW=Blacet Mini-Wave
MMV=MiniMoog Voyager
DSC=Blacet Dark Star Chaos
sir_dss,
Cool, thanks - looking well forward to the miniwave
Just out of interest, how does the sound of the motm oscillator compare with that of the voyager?
gd
As an alternative to the dark star, check out Wiard’s Noise Ring. Grant Richter is regarded as one of the best designers out there so this should be an awesome module. It’s certainly on my list ![]()
the learning curve has begun, thanks all. I will have to rely on your expertice as I just haven’t found anyone here, Toronto Canada area who is into the modular setups. I was in Chicago last spring and heard one being played and I am sure that thing “growled” it was an spine chilling earth shaking sound. I only wish I had had the opportunity to talk with him about his setup.
suthnear
So far I only have the MOTM 310 mini VCO so it’s not fair to compare to all the deluxe waveforms from the MMV. I should be getting 2 MOTM 300 Ultra VCO’s soon. That will be much more fair comparison.
I really really hate terms like these when describing sound but…
I will say the MMV sounds rounder, smoother than the 310. That’s one MMV VCO, an equal way to judge.(I patch the MMV VCO from the effects loop. I believe the MMV VCO signal is unfiltered at that point).
Yet the 310 does not sound harsh or cold. It’s just present. It has that warmth and almost cozy(some say wounded) structure. And it’s true, very stable tuning. I like it! I’m glad I went with MOTM. I do wish they had a oactive switch on their VCO’s though. Someone does make a module for this though sometimes. Larry Stooge I think.
I want a Noise Ring too. I see a MOTM custom version on the website. Wow. I need to make some $$$!
what book would you guys recommend that I buy to start my edumication.
hey guys
i’ve never used a modular but I plan on getting one soon but unfortunately
i am poor
but i want to get something and slowly build it up
i’ve been looking into Doepfer and MOTM
what are they like in comparison
any advice would be great
thanks
- Electronic Music: Systems, Techniques, and Controls by Allen Strange
- Electronic Music Synthesis: Concept, Facilities, Techniques by H.S. Howe
Those two old school books helped me tremendously. They’re the best for understanding concepts. Not really synth specific.
Yeah, I’m cash poor too, like the rest of us. Cadillac tastes on a Chevrolet budget. ![]()
For books, I’d recommend Synthesis by Herb Deutsch. Herb used to work with Bob in those halcyon days of youre that many of us long for. I’m sure the book is out of print by now. (A recent search on ABE Books (USA) showed three copies available, ranging in price from US$32 to US$100.)
By the way…who or what is MOTM? I know that MOTU is Mark of the Unicorn, but haven’t a clue about what MOTM stands for.
MOTM is the company synthtech. synthtech.com
It’s slowly becoming the standard for modular systems that use 1/4" jacks.
Some would argue that another company, syntheisizers.com is. But there is a pretty strong family for MOTM systems. People do convert other systems like blacet, and Ken Stone modules over to MOTM standards with the help of Larry Stooge of wiseguysynths.com. Larry makes these incredible faceplates that match the MOTM system format.
synthisizers.com make some nice traditional moogish modules. I also understand he gets you your modules rather quickly, and that is hard to do with most modular systems. John Blacet is also rather prompt with orders I’ll add.
Doepfer, has a large number of modules. I’ve been thinking about their theremin CV control module and frequency shifter. And also the Analouge Systems EMS clone Filter and Trapizoid Generator. But I would want to convert to 1/4" jacks since those seem a bit reliable to me and will interface with the Voyager better.
Note that MOTM, synthesizers.com, blacet use a +15 -15 v
while the Doepfer, Analouge Systems use +12 -12 v
You need diffrent power supplys for them.
I copied this from a Pro Audio Network article:
MOTM stands for “MOTher of all Modulars,” and though that’s quite a claim, the exceptional quality of Synthesis Technology’s system might validate such hyperbole.
