Sorry that you are having trouble, it can be confusing. It might be a good idea to look at how MIDI works and understand the difference between Note number (key location) and CC (127 different parameters that can be assigned to various things and vary per piece of gear). You take that info times 16 channels and that is a lot of info that can be sent!
Here are my notes taken from the manual that explain everything I like to do with it over MIDI:
SETTING THE MIDI CHANNEL
The MIDI MuRF Defaults to MIDI Channel 1 for receiving Channel Mode messages (MIDI CCs, MIDI Note Ons). The MIDI Channel can be set by the user one of two ways: powering up with the LFO and FREQ switch in the left position and with the stomp switch pressed sets the MIDI channel to 1-12 corresponding to the position of the pattern rotary switch. In addition, a MIDI CC #102 with values 1-16 received on any MIDI Channel will set the MIDI channel to 1-16. When the MIDI MuRF is powered down, the last MIDI Channel assignment is remembered.
Using MIDI Program Change Messages values 0-23 accesses the MuRF patterns 1-24. This has no impact on the position of the FREQ switch, so that using MIDI, you can use any of the 24 patterns with either voicing,
MIDI Channel: CC102. Values 1-16 = MIDI Channels 1-16
ENVELOPE: CC1 (Mod Wheel)
DRIVE: CC2 (Foot Controller).
LFO RATE/SWEEP: CC3.
OUTPUT: CC7 (Volume)
MIX: CC8.
RATE: CC9
FILTERS 1-8 LEVEL: CCs 20-27
the CC value sets the volume of the corresponding filter up to the maximum volume set by that filter’s slider. Note that the values of CC20-27 Messages do not override the positions of the sliders
Pattern Reset: CC90 Any Value. A CC90 message received will instantly reset the current pattern to the beginning (step 1). This is useful for re-synchronizing the pattern to an off-beat while you are in MIDI sync.
PATTERN CLOCK RESET: If the pattern clock is running, MIDI Note 65 will re-set the pattern to step 1
Pattern Clock Sync On/Off: CC89. Values 0-63=OFF; 64-127= ON.
FREQ BASS/MIDS: CC86; Values 0-63=BASS; 64-127=MIDS.
LFO ON/OFF: CC85; Values: 0-63=OFF; 64-127=ON.
ENVELOPE SCALE: CC70: CC70 expands/compresses the overall duration of the envelope while keeping the same shape set by the ENVELOPE control or CC1. Using CC70 you can control the envelope time scale independently of the Rate control.
STEP MODE: Note On Value 108
MUTE MODE: Note On Values 24, 26, 28, 29, 31, 33, 35, 36
STACCATO MODE: CC68 OFF/ON (0-63 = OFF, 64-127 = ON). This mode changes the way envelopes behave in “Triggered Mode” (See below on p. 21 for Triggered Mode description) If this is OFF (which is the default), then the envelopes go all the way through their attack and decay no matter how briefly you hold the MIDI note. If “staccato mode” is ON, then the envelopes play all the way out if you hold down the MIDI note, but if you release the MIDI note the envelope goes immediately to zero.
TRIGGERED MODE: Note On Values 48, 50, 52, 53, 55, 57, 59, 60
If a Note On is held until the EGR goes through its complete attack/decay cycle, a new Note On message is required to retrigger the EGR. An EGR is retriggered from the last point in the EGR cycle if retriggered before the Decay segment reaches the end of its cycle. This is an “8-voice polyphonic” mode – so up to all 8 filters can be fired at once (in the order they are received serially).
SUSTAINED MODE: Note On Values 72,74,76,77,79,81,83,84
the corresponding filter is set to a level determined by the Note On Velocity. When the Note Off message is received for that same note value the filter’s DAC Value is written to zero. This means you can “play” the filters in a sustained fashion with Note On messages.
NOTE PRIORITY: Triggered mode and Sustained mode can be used at the same time, with the last note played taking priority for the corresponding filter.
Sustained/ Trigger Mode cannot be used at the same time as Mute Mode so if any Sustained/ Trigger Mode Note On messages are received, any Mute mode Note on values are ignored. Note that if the clock is stopped by Sustained/Trigger/Step Mode Note On values, a Mute Mode Note On does NOT restart the clock – clocks are only restarted by changing the Rate control, changing the Rate input CV, receiving CC9, or by receiving MIDI Clock start or continue message.
Sustained/ Trigger Mode cannot be used at the same time as Step Mode so if any Sustained/ Trigger Mode Note on Values are received, Note on value 108 is ignored. A Step mode note (Note On 108) received after Sustained or Trigger Mode Notes will place the MIDI MuRF back into Step mode.
Mute Mode cannot be used at the same time as Step Mode so if Note on Value 108 is received, Mute Mode Note on values are ignored.
MIDI CCs 20-27 are treated with priority over the Note On Modes to control the levels of Filters 1-8.
