Any way to modulate Spacing on the Matriarch?
Does anyone know if its possible to modulate the filter or delay Spacing knob on the Matriarch? I would love to be able to have them pan left and right.
Can you do it by modulating via the Cutoff 1 In? I think if you were to put a blank into Cutoff 2 In to stop it following Cutoff 1, you would effectively be modulating the spacing. And I think you could do the same with the Delay, but by using the Time 1 In and Time 2 In. If sync is on, then Spacing will use clock-rate divisions - I’m not sure what the behaviour there would be if you were sending a signal to Time 1 in.
