was rendering some audio out the phatty some bass parts, 2 of the same parts rended within 10 secounds of each other and the parts were in totaly different keys.
any good tips to keep the Slim in tune
how do you warm it up with auto tune on or what?
do u keep auto tune on all the time or set it to off or fine tune?
Fine tune is either set to off or auto, couldn’t be both at once.
I leave fine tune set to Auto and make sure to let the unit warm up for a good while before I start recording tracks. You can flick back over to the Fine Tune page and make sure it reads 60.00 to be sure it’s in tune… just be sure to leave this page (or at least make sure the cursor’s not under the number 60.00) before playing/recording, as the output is muted when you cursor under the note number.
In short though, make sure the unit’s fully warmed up and fine tune is set to auto and you should be sorted… I had no problems while following this advice even with 4 slims all playing in a stack.
edit: also make sure your Slim has the latest firmware, at least version 671 if not v672 which I just posted to the “v3.1 firmware” thread and which will be on the main website shortly.
Were you driving pitch with CV, by any chance? I have found on the LP, if you have it set to ‘Auto’ and instead of the keyboard/MIDI you use the
CV in, the pitch just goes crazy and you wind up with wacky transpositions. I would retry with tuning set to ‘off’
Yer amos sorry thats what i was trying to say it was set to auto so it was off, it had been on for around 3 hours so it should have been warmed up an i had just checked it was at AUTO 60.00 then recorded the fist recording was fine 10 secs i recorded it again an that was right out of tune.
i am using v672
