Has anyone noticed that there’s a difference in behaviour of the octave up and down buttons depending on whether or not the “compare” button is lit? In normal mode, when a note is held and the octave up or down button is subsequently pressed, the pitch jumps octave immediately. By contrast, if the “compare” button is lit then, when a note is held and the octave up or down button is pressed, the note stays in the same octave until they key is released and re-pressed. I actually prefer the latter behaviour and it would be great if the option to choose between the two behaviours were made available in a patch and/or global menu.
Just had a reply from Amos and he told me that this “delayed transpose” was recently added to the Sub Phatty and will be included in a future Subsequent 37 update!
