Animoog wants to visit store and fetch products
I’m new to Animoog, but let me describe to problem I’m having. I’m using animoog on a Wifi only Ipad 3 running IOS 6.0.1
Im playing using the speaker headphone out and no other interface, not connected to any network and have Wifi disabled. I have left the pad untouched for a few minutes while playing another part on a keyboard and when I return to the animoog it has switched from the x/y pad screen to the store screen with the message “One moment please, Still fetching products”. I then have to tap OK and then switch back to x/y pad screen. Happened many times thru the session. Does anyone know if there is a setting or an Ipad config to keep this from happening?
never seen this… are you new to animoog or have you used it previously? Did you use animoog on this same iPad with an earlier iOS? I am curious to see if perhaps it’s a new behavior on the newest iOS, since as far as I know, nobody’s reported this behavior until now.
It was an ios5 then I downloaded the most recent animoog and then upgraded to ios 6, always on the same ipad3. It is a wireless only ipad and it only happens when not connected to an available wireless, which is not very often. Im hoping its just a setting that i can disable. Im sure the other patches are good but id rather initiate a search for new content manually.
Thanks for your interest.
Hi, I have a related issue. Just installed Animoog 2 on iPad 3 with latest iOS. When I try to go to the store, I get a message “Fetching Store Items” but they never download so I never get to see the store items. Any ideas what is going on?
