I’m sure that when I’ve downloaded this amazing app I could hear sounds from speakers too!!!
Every other apps works fine, but animoog, suddenly, not!!!
Maybe I’ve modified something in the app, but I don’t know what, and I’ve re-downloaded app two or three times, and I’ve not resolved.
Any ideas? I think it’s a bug, there’s a way to communicate that?
I heard this is only happening on iOS 5, is that what you are running? It happened to me and this fixed it (I either read this here or on gearslutz):
Go to settings on your iPad
change the side switch function to mute/unmute rather than rotate lock
Flip the sideswitch until it is clearly in unmute setting — you should now have sound.
You can change the switch function back to rotate lock now if you would like.
I hope this works for you guys, it fixed my issue.
Thanks - worked for me too (my side-lock switch is set for mute on/off anyway). Why had I not thought of it before? Prob because other apps don’t behave this way, I.e. the volume button usually over-rides the mute switch.
