Having a lot of fun exploring the CC mapping using automation.
One bug though: when Animoog runs in the background CC automation stops. When switching over to Genome sequencer to draw/tweak CC curves, Animoog stops responding to CC messages, though it keeps playing the sequence. I tried different CCs and different parameters on Animoog.
Would be nice to get CC feedback from Animoog while switched to background mode.
switching back to animoog and having the DAW running (Beatmaker2 in my case) results in playing the CC automation, tho. still not the desired workflow when I want to make changes to patterns etc.
In another thread there is the solution (that worked for me), you’ll lose your presets though.
Delete Animoog from iPad,
got to iTunes and re-download the app
No, this is a problem when selecting a category. I sometimes only see 2 out of 10 presets (in my user folder for example, but it happens in others as well), sometimes see none, etc. I then have to tap on another category and then tap on the user category again. Sometimes all my presets will then show, but sometimes it is again not complete, so i do the same (tap on another cat. and then back) until they are all there.
I’m not sure if it is happening as often with the other categories because most have 20 to 100 in them so it’s hard to tell without counting them all if they are all there. But i have noticed in some of my folders with 20 or less that there are some missing randomly. Again, i just click off and back on and eventually they show up.
