I just picked up an MFB Urzwerg Pro II sequencer, and am having trouble getting it to work as I would like with my Voyager. I send the CV to the Pitch input, and the Gate to the Envelope Gate input, and nothing - unless I hit a key, then I hear the sequence. Problem is, how do I get to to run without holding down a key? It works that way with the Oberheim SEM Pro, so I’m sure it’s simple and I’m missing something…any advice?
If you had read your Voyager’s manual more carefully, or done a little search on this very forum about it, you would have known to put the Volume Envelope “Env/Gate” switch to the On/External position in order to keep the VCA open all the time… ![]()
