Analog Track Mode Bug and others
Is anyone else experiencing this bug?
Filter cutoff, Resonance, EGR Amount, Overload, FiltEnv Sustain, OSC 1 & 2 Wave are effected when I am using Logic 9(happened in 8 too) connected via USB or DIN. With the LED and knob starting at 0, the LED and parameter increase too fast. So by the time the knob makes it 12 o clock, the LED is maxed out. Also, Pass-Thru mode works intermittently, only “catching” the LED sometimes. Snap mode seems to work just fine. I’m also experiencing many hanging notes.
I read a post from 2011 about it being addressed in an update but I’m running 3.21 on a white LP Stage II.
I put my money on a MIDI loop :slight_smile:
Hmmm, you know one thing I didn’t look at was the midi merge settings in the LP. I’m only connected via USB to Logic though. Any suggestions on things check in Logic?
I don’t know Logic enough to give you clues in there, but you may want to check if this happens when only a MIDI cable is plugged (Moog OUT to Logic IN).
This turned out to be a midi loop. To eliminate it, I turned local off. However, now when I use the pitch bend wheel it sounds steppy/not smooth. 14 bit mode is on. Anybody experience this? This has been very frustrating.
