The T-3 manual states that when in Master Mode/analog mode, the factory default setting is “Track”. When I checked, mine was set to “pass-thru”, and when I set it to track mode, the selected parameter’s value will adjust up, but will not not adjust down below the preset’s stored value - has anyone else experienced this? This only appears to be an issue when I’m in track mode - snap & pass-thru modes appear to be unaffected.
Update - this issue only appears to be occuring when, selecting the parameter to be adjusted, the control wheel is set below the preset’s stored value - if the wheel happens to be above the preset’s stored value, then the entire range of the parameter is available.
Track mode is still a work in progress – we hope to have it all smooth and proper in the v1.1 firmware release (coming soon). Until then, that’s why the default mode is Pass-Thru for now…
Thanks Amos, I’m know you’ll take care of us. When v. 1.1 comes out, will I be able to load it via USB cable, or will I need some sort of MIDI interface? I have a PC, running Windows-7 home edition, and computers and I don’t always seem to play well together…
Amos, you rock… Btw, I would like to volunteer to be a beta-tester for future Taurus OS updates. I’m digging deep into this bad boy, and I’m lovin’ every minute of it!
