Hi Amos, Just trying to setup the sub37 got it working great, but having a bit or trouble getting the SEQ to SYNC to Ableton
could you let me know the best full setup in Ableton 9.6 Windows10 ?
mesa
mesa
depending on what you are trying to do, there are a few variables.
Most generally though, go to Ableton settings, MIDI page, and make sure SYNC is enabled for the Sub 37 MIDI output.
On the Sub 37, make sure the SYNC button is lit in the Arpeggiator section (this sets not only arpeggiator sync but master sync for the Sub 37 to external/MIDI, so it’s needed if you want the LFOs to follow MIDI clock as well).
Then, to trigger the sequence in the Sub 37, program a single long MIDI note in Live, equivalent to holding down a key on the keyboard to trigger the sequencer. Or if Latch is on, you can use a short note to trigger the sequence and it will stay running…
That is the most basic info. If you have additional questions, just ask ![]()
