always a struggle with matching a pot or button position/value
When editing i always struggle with matching a pot or button position / values being correct against the saved value of a sound,
or knowing if a parameter with a zero centre position really is centred .
A simple way is to work with different coloured dots on the display, for example when in pass through mode a white dot appears on the home or edit screen for being correct on the saved value green for centred value blue for full left red for full right and so on.
So you have to press nothing to see if you are in correct position for the pot turning or pressed button right now!
This would very simplify editing!
