Ableton Sub 37 Editor
Hello,
I’m Chris and I want to post my little helper to the forum. :slight_smile:
Ableton Live “Sub 37 Controller/Editor”
This Device made in use/help with:
  • MIDIPhat 1.2 by Telegraph909
  • NRPN Gen 0.3 by gbravetti
Features:
  • Remote your Sub 37 with the relevant CC & Nrpn accessable Parameters (include LFO/MOD Assigns).
  • OSC2 Freq Parameter: You have the Choice between 7bit “normal” and 14bit “high” Resolution.
    Notes:
  • Save your Patches for sure in the Sub 37 Hardware.
  • Save your actual “Edit Buffer” before start the Device.(Edit Buffer will be lost!)
  • Caution with “automate” Nrpn Parameters in Live! Nrpns are much Data intensive…
  1. Start Device
  2. Load a Patch in your Sub 37 Hardware
  3. Control :slight_smile:
    I hope You like it and it helps!
Best,
Chris!
:open_mouth: Fixed a Bug in LFO/MOD1 & LFO/MOD2 OSC`s Pitch Section. Now it works correct!
  • Update Pitch- Wheel Section.
Download Link:
https://www.dropbox.com/sh/3o3hkblemsb72or/AACqq2LzyIX9jGUujdsytjkXa?dl=0
Chris,
This looks Awesome!!!
Thank you!!
I’m looking forward to trying this with the sub 37, the Max 4 live device itself looks promising :slight_smile:
thanks for your Reply!
There is a new update! :bulb:
  • Free Window GUI to access all the Parameters on Top.
  • VCO Wave Parameter: Addet Quick set Buttons for “pure Saw” & “pure Square” Waves.
Best,
Chris!
Looks good going to give it a whilrl! Cheers. :smiley:
Hello!
There is a Editor- Update with several little fixes… :wink:
Best!
