I have synced my phattys LFO to Live (think its working), now when I press the panel active encoder in preset mode it goes to mid clock and keys don’t work when pressed on the synth, is this normal?
Hey mate, I have got a midi loop, arp seems tor work now after shutting down the LP, though the value encoder once pressed still shows midi clock instead of arp?
The lfo isn’t perfectly synced? it still re triggers at the start of the one bar loop even though it might not have finished its cycle, not sure if these things clock super tight or not?
LFO setting in the Phatty Global was set to 1/4 I think? but if I played back the recorded midi automation in live the phatty Global would cycle through different settings, 1/4 1/8 1/16 and about every setting in there, the LCD would display every change quickly…
Ableton needs to be actively playing for the arp to work whilst in midi mode, otherwise no noise will come out at all let alone an arpeggiated one… took me ages to figure that out
