Hello,
I have bought Theremin Etherwave Plus via thomann.de, the first thing I have got is an adapted that was not for theremin at all, but some other Moog instrument. It took 10 days to get another adapter.
Than I have the following problems today I have started for the first time:
- The distance between the lowest note and antenna is very short. Even if I calibrate to the longest distance it is just 15 cm. Is that OK? seems to be to short.
- There is a constant 50Hz sound, that is kept all the time. I never get pure sound, but distorted in a way (pitch + 50Hz pitch). When I am on the “bottom pitch” (so to say when the pitch is zero) than I still hear 50Hz pitch.
- When i go down with the dynamics it is OK, until I touch the volume antenna, than it happens a buzz, high pitch, and even if I hold my hand on the antenna and move slightly, I get high pitch buzz.
What I am doing wrong?
