a six pack and some power
So at this point I have the six pack and a cp251. I’d like to find a convenient power solution. Has anybody tried the Voodoo Labs power pedals II. With 7 or 8 MF’s?
Thanks in advance
Dean
Dean, this thread may be useful to you:
http://www.moogmusic.com/forum/viewtopic.php?t=6178
Your PSU should be at least capable of supplying the sum of the current drawn.
Some say toroidal transformers are better than switch mode; I have a DIY version using a torroid for my rig (yes, yes, I’ll show you soon!!!)
I use a Voodoo Lab Pedal Power II. You have to make sure you get the reverse poloarity power cables to rub to ‘Foogers. One downside is that the reverse polarity cables only come one size 21’’ if you get them from VL. You will also run into problems if you try to run too many 'Foogers from it, but you should be able to reduce your wall worts by 4.
