I’m thinking of buying a Slim Phatty or Minitaur.
Got a couple of questions, hope you can help me out a bit.
- Is the Phatty capable of creating raw, modern sounds?
- Would you recommend it for a EDM/Techno producer? (music style: http://youtu.be/zYk22-HO19o)
- Is the Phatty filter the same as the Minitaur filter?
- Does the Slim Phatty output its arp data via the MIDI out? (to arpeggiate another synth)
- I allready own a Virus TI for lead sounds. Would you recommend the Phatty as extra synth?
- Does the Phatty take 30-40 mins to become totally stable in its tuning?
Thank you
4- My Little Phatty (SE2) can either send arpegiatted notes or keyboard played notes via MIDI. Last OS here.
6- My Little Phatty is full op in a matter of minutes, say 10-15 max. I’ve read the Slim Phatty generally takes longer. If you live in a not too cold region, this is less a problem though.
You’ll like one or the other
Any more users here who could help me out here?
I’m still not sure if I should buy the Minitaur (second hand about $525) or the Slim Phatty (second hand about $610)…
I have an LP not a SP but they are the same. Used to have a Minitaur. The Minitaur has massive bass, but so too does the phatty. And the phatty can do loads of other stuff too, so I would go for the SP personally.
A second vote for the Slim Phatty too…
Never had a Minitaur, but the Slim is capable of só much more, that it’s simply a no-brainer from a musician point of view. The bass on the Minitaur is certainly better, but it’s also way more limited. The Slim is just an “all you want” Moog.
I use both and certainly think the Slim is a superior product; I center most of my music around it now. In fact, a $525 Minitaur is a bit overpriced for a second-hand unit.
