Could anyone with an original Moog 904B HPFilter make a couple of checks for me please…?
I have built two of these myself and although they work perfectly - I am getting ‘thumping’ on the output and it’s passing audio from the control inputs.
Thanks for your comments MC - it’s actually sorted.
The notes on the schematic are misleading though… it’s not Q’s 13/17/21/25 & Q’s14/18/22/26 that need matching. The wording could be better there.
They actually need matching on the pairs which work together: 13/14 - 17/18 - 21/22 - 25/26.
I used the hfe function on one of my DVM’s and not that Moog circuit, but I am aware of the error.
Also C19 is wrong… it should go to ground and not the -6v rail.
I also ‘upgraded’ the circuit with a slight addition. I a/c coupled the audio amp and also put in a trimmer to clamp the base of Q27 to zero.
I think there was a factory upgrade which added a couple of caps on the rear of the board around Q28, which I also performed.
