351 and 352 expander accessory cable: Ugliest cable ever!!!
Why did they have to pick an ugly ass conservative grey cable for the accessory ports? Why not black, or silver, or brown, or even white, but grey??? Ewwww.
Nit picking..I know…
you know, I was thinking the same thing just last week. I will see what our options are.
Amos
Ooops…busted talking smack about Moog by the “Moogman”.
Great minds think alike??
Maybe? :smiley:
Thanks Amos! Not really a big deal,
but aesthetics are a part of moog products
and that cable says ugly all over it.
Is it a standard cable that I could replace?
Thanks for listening…
Now go make that Moog CP252-Enveloper and finish the MF109 Mooger-coder Vocoder
:laughing:
Good comeback, Amos :smiley:
BTW how did you enjoy your first NAMM show…?
Hey! Don’t rush the man, he’s too busy working on the affordable polysynth and the sequencer, of corse.
:stuck_out_tongue:
What’s wrong with dark grey? Not as good as black, but the cable that came with y Voyager was BEIGE. Yeech…!
SEQUENCER? SEQUENCER? Are we talking STEP sequencer??? I talked about this to someone at MOOG MUSIC sometime last fall. Whoever I talked to though it was really neat idea… but back drawered it for the time because they were polishing up Little Phatty.
Could it be… ?
Hello,
I believe Cikira posted up on this some time ago. This thread:
http://www.moogmusic.com/forum/viewtopic.php?p=550&sid=64a114d9d9af4aa17b25519ebc1057b5
Mine was purchased from Montek (IIRC):
http://www.montek.com/cart/catalog/6-Male-to-Female-Extension-Black-Heavy-Gauge-p-25724.html
There are probably more sources if you need to compare prices.
Regards,
Lawrence
Yes and they are building a new Modular SYnth too. A Polyphonic Modular Synth with a sequencer, and its all contained in an affordable Moogerfooger style Stomp Box.
Right Amos?
:laughing:
umm… yeah. :wink:
As for the cable it is a standard “DB-25” cable, which comes in two varieties, twisted and straight-through… you want the straight variety.
Belkin makes one in classy black for about 12 bucks.
You know after recieving both these units today.. and putting them into the rackmount it looks like it wouldn’t be impossible to have cables coming out the back instead. Would require extra holes cut in the rackmount bracket.
It would take a fair bit of dismantling of the front panel of the VX’s but it would just be a bit labourious I think…
Basically unscrewing the pots and the 1/4" connectors from the front panel… as far as I can see they are the only thing holding the PCB to it.
Then route the socket round the back instead, plenty of room to do this.
classy black
Yup, so we can safely put the pc-coloured cable in the category “not classy”. Does not go well with extremely classy synth gear such as Moog. :wink:
Yeah the beige ones are pretty lousy.
I just bought a pair of these, just in case anyone else in the UK is the same aesthetic predicament :slight_smile:
http://www.maplin.co.uk/Module.aspx?ModuleNo=97739&criteria=rs232&doy=23m5
It was a very simple job taking the PCB out and routing the DB25 ribbon through behind the PCB instead. I’m going to take it all to a local sheet metal shop next week and get the DB25 ports mounted on the back of the 19" Rack with black blanking plates covering the holes on the front. The ribbons are just long enough to do this comfortably.
Aside from the holes cut in the Rackmount it would be simple to put it back in its original form.
Some tips on taking it apart.
Accessory port: Simply unscrew the bolts.
Pots: Take off the knobs and remove the nut and washer. Be aware there are also some washers under the plate.
Jack sockets: Just rotate the plastic top by roughly an eighth of a turn anti-clockwise. I used a pair of pliers with some plastic tape around the end to protect the part, I found I can put them back on afterwards using my fingers.
Will post some photos when it’s done.
awesome, thats an excellent idea… nice blanking plate in the front to cover the port and just swapping them for the rear of the rack.
Thanks Amos for the cable info! black is the better option for sure
It’s still not finished, but you get the idea.
I intend to take better photos so I ask that no-one uses or links to these images elsewhere without my permission.
fuking perfect!
I was thinking of this cuz I wanted to put a patchbay on top to send to the IO on a vogager select with a snake to the rack, to have all the connectors right on top of the 351 and a 251 and then rack like 3 foogers underneath and have it all clean and do all my patching at the rack and not having to change any cables at the voyager. but the multipin connector in black and in the rear is even cleaner.
sweet idea
Thats a sweet lookin setup. Is that a Vx351/2? Could you put that on the edge of the table and extend the rails downwards or continue to extend them upwards to hohuse some Foogers or would that be pushing it a bit on the Center of Gravity?
Great pics, and Ive never really seen any of the back of the RME before.
Its very interesting how different people get their rigs goin.
Yeah it’s the 351/352.. they really weigh nothing so the heavy ole RME keeps everything solid. There really is no wobble or sense of unbalance.
I guess you could possibly hang things off the front.. I’ve never seen (or more to the point held) a Moogerfooger.. but if they are as packed as the RME blatantly is then I’d imagine they are kinda heavy?
I prefer to Keep the Prophet 08 in front :wink:
