2 x Mother 32 and Ableton
Hello,
I have a problem setting up 2 x Mother32 with Ableton 10 through RME UFX interface.
So from the 2 outputs of Mother 32’s to the RME UFX’s input ch 1 and 2.
The problem is that when I play them i can hear them mono, 1 Mother32 in the
left speaker and the other Mother32 in the right speaker. Do I need a MIDI cable as well?
Any help would be appreciated.
Sounds like you have the RME’s input set up as a stereo pair in Ableton.
Check your settings in input configuration and check that you have “1 (Mono) & 2 (Mono)” selected.
good luck
p.s.
You won’t need a MIDI cable. This is an audio routing issue, not MIDI related.
