Ahhh, soo, ya, I appreciate any response hear as I feel like I"m on a wild goose chase… Total noob question, Can I hook up 2 M32 and 1 DFAM with a single Komplete Audio 6 interface? I can get two to play, obviously that one is pretty easy just take the audio out from each one to the Main input 1/2, but I’m thinking that I can’t play the 3rd M32 at the same time, although this must be possible. Is the routing here achievable? And if so what would you do? I soooo appreciate any insight here, on a steep learning curve right now! ![]()
This should be no problem, as that interface has four analog inputs. Just make sure to check the settings on the Komplete Audio so that all the channels are routed correctly.
You could also send sound from one device to another with patch cables. Either VCA, VCO pulse or VCO sawtooth into the external audio input.
