104M Tap Tempo problem
I was very fortunate to acquire a 104M recently, and while the sound and features are incredible, I haven’t been able to make the tap tempo work. Tapping it doesn’t change the tempo of the LFO or delays and neither of them turn green when tapping (I know to tap 3 times, and that holding down is supposed to shift between LFO and delay). Any suggestions on what to do/look for? I got this used, and know that there are a bunch of tweaks for Moogerfoogers, so I don’t know if there’s some setting issue or if there’s something wrong with the mechanism itself. Thanks!
Hi mcscotch, welcome to the forum :slight_smile:
I would bet on the switch itself. As fat as I understand, none of the actions involving that left switch are working; I’ve read about tap tempo bugs but what you describe is more than that.
Keep us informed!
Have you tried updating the firmware and calibrating? That might be worth a shot
The other reason for it not to work is if it is receiveng a MIDI CC which overrides the tap, I ain’t sure if the CV input overrides the tap as well
