104M send in Ableton
I hope this is not a repost!
I use Ableton Live and I want to use my 104M as a send in all my channels. I usually send audio from a synth through it and then record in my sound card. In other words I don’t know how to use it on the sounds coming from Ableton.
Let me know your thoughts. :slight_smile:
Create a “Return Track” then drag and drop the “external effect” from the effects browser. In the settings for the effect, you will choose the audio input and output channel, as well as tweak the latency. Then to send a specific Insturment to the 104, use that “send amount” “knob” about the level in the mixer, next to the pan.
Message me if you need more help
Hello
Really struggling to set the moogerfooger MF-104 delay as a send with Ableton using Focusrite Scarlett 18i18.
Please could you explain each connection and routing?
Many thanks
Jason
First you have to configure the send/return path…
  1. at the Scarlett MixControl the DAW5 is routed to Line Output5 (or any other free channel)
  2. in ableton an external Audio Effect is created with send/return channel 5 (Audio To /Audio From).
After connecting (physically) the MF-104M to send/return channel 5 you can use it as an external effect:
