104m guitar clips
Can’t remember if I was using the OSC out of my ring my to control some parameters. The recording quality is not that good but you still here the characteristics of the delay. Enjoy!
http://soundcloud.com/j_roc-2/20120718-155217
Listening now – cool!
http://soundcloud.com/j_roc-2/square-reverse-ramp
Here’s me using a ring mod which is chopping my dry signal into squares, and the OSC out is controlling the rate of the LFO. The LFO is reverse ramp and the amount is 10.
The tap tempo of the delay time and LFO are synched to the tempo of the ring mod. The recording doesn’t capture it completely, but it is very musical when you strum the guitar percussively to the beat. Reminds me of the keyboard attack on wonderful christmastime lol.
Also there’s some RV-5 in there.
Some sample & hold at the end for you!
http://soundcloud.com/j_roc-2/mostly-feedback
Playing mostly with the feedback here. The chirping sound happens when you tap past the “allowed” delay time. Enjoy! Props if you listen to the whole thing!
Your clips sound great! What reverb are you using (and amp, guitar, ect)?
I just ordered the 104M and have been researching what people have created with this pedal.
Thanks! For the “mostly feedback” I’m pretty sure the Reverb I was using was only the JMI Reverb/Top boost unit. I have a JMI 30/4 amp with Celestion Blues and a 52 hot rod tele, but swapped the pickups for Lollar t52s (with a regular single coil neck pickup). The swells at the start are from the Fairfield Circuitry Randy’s Revenge; the lowpass filter built into it helps create a nice ambient sound. Pretty sure I wasn’t using my tube tape echo or boss rv-5, but those are typically in my chain (with the RV-5 before the tape echo). In the reverse ramp one I was using only the RV-5 for reverb I’m pretty sure. I only use the modulate mode with the RV-5. Recorded with my iPhone.
