I ran the calibration overnight and this morning began playing with my own presets to see how they sound. Troubled to discover that since the update the default for EXP 1 is volume and for EXP 2, filter. That would be cool under normal circumstances but many of my presets already have pedal assignments. I had to go through each of my presets and shut off the EXP 1 + 2 defaults, then Save. Even presets where I have no pedal assignments were borked because filter settings are negated by EXP 2. All of the factory and 3rd party presets that I went through are also affected by these defaults, as is INIT. The default should be NONE and let the user assign the pedals later in the programming stages.
Anyone else encounter this?
