on switching Sub 37 ON Editor shows last preset as on Sub 37
however Librarian does not highlight this preset
only highlight after selecting this preset with bank/preset in Editor
used bank 1 preset 13 (STRINGOTON) for test
rest of setup as per signature
does same after Sub 37 switch OFF then back ON as does the Editor (OFF then ON)
is this the expected behaviour?
Found out when you scroll or even touch the scroll bar.
The preset appear.
Regards Luloop
Well, ideally it should highlight once connecting to the synth. Probably reported in the past and not a high priority issue at the moment. Is everything else running stable for you ?
it all runs fine
