1.06 Update Nightmare
I tried running the update on my Sub 37 from my OSX 10.9.5 machine. The update didn’t work so I tried a second time. This time the Sub 37 displays the message “Flash Erased Ready For Code” but when I press Send the word Done appears in the status bar immediately. Further, the Sub 37 doesn’t appear as a MIDI device in the Config menu. The Mac’s Audio/MIDI setup program confirms the Sub 37 is no longer online.
I’ve tried power cycling the Sub 37 but that didn’t help. The same message appears.
Can someone please help fix this?
Heads Up, Problem solved…
I powered down the Sub 37 and the Mac. When I fired up both devices I was able to see the Sub 37 on the list of USB devices and I was then able to re-do the update. My Sub 37 is now up-to-date with the 1.06 patch.
As others have mentioned, I’d like to see a simpler, Moog-based update procedure.
I love this little synth and was devastated when I lost it for those few hours.
