after installing 0.9.43/1.1.23, when I change any GLOBAL SETTINGS (Local Control, Pitch variance, etc.) or MIDI SETTINGS on hardware (Channel, PORTS, etc.), the standalone Editor does not reflect change. (Changing on Editor successfully changes hardware)
This issue occured despite doingt he following for install:
Removing AppData\Roaming\Moog Music Inc folder prior to installation
power cylcing the hardware after installing latest firmware
I checked 0.9.41 (with 1.1.23) and it works as it should.
FYI I’m running on windows 10, 3.30 driver, using the 64-bit Stand Alone Editor
