Re: MF-109M - yet another VCA/EnvGen mockup
Posted: Thu Mar 27, 2014 1:39 pm
Panvelope?
Here is a version with some of the suggestions included and a back panel for discussion purposes. The Dual envelope outs are Insert style TRS outputs (to cram both outputs into the back panel). I didn't label the inputs as audio, since I am hoping we could use them for any AC or DC signal. I dropped the sensitivity knob since the Drive could do the same thing I think. The Pan Knob would only pan using the first input and disable the second input when it isn't in the off position (weird I know). Length is cool as it could act as a frequency input when looping (creating a potential VCO?).
I think there could be special modes activated by MIDI that could turn it into a voltage sequencer (sliders could go up for output 1 and down for output 2), amplitude sequencer or even have the sliders turn a trigger on or off so you could program your own 8-step gate patterns!
One of the patterns should be off and another should be random triggers (different on both outputs). Maybe you could select more memory banks over midi (like being able to do both sets of MuRF patterns).
