Moog Music Forum
Share Ideas and Pass the word
DOes your etherwave click when the volume antenna is touched
Share your theremin experience: tips, tricks, techniques, favorite theremin moments.
Postby EricK » Thu Mar 16, 2006 7:11 pm
Does anyone notice any clicks from the Etherwave standard when the volume antenna is touched? Mine used to sound totally pristine until i took the antennas off. I babied it properly like all moogs should be but the more i reassembled it the more i noticed that it clicks with you touch the volume antenna. It seems to work just fine though.
Postby Fort Pempelson » Tue Mar 21, 2006 8:13 pm
me too, unfortunally.
would be nice to hear about solving the problem...
(solder station rigth beside ;) )
thereminique greetings,
guido
Fort Pempelson
Postby RFBB » Thu Mar 23, 2006 4:59 pm
I have removed my antennae on numerous occasions and have yet to experience this problem and hope that I don't. Hope it's an easy fix.
RFBB
Postby Hutschi » Wed Mar 29, 2006 9:10 am
I built my own etherwave theremin from a kit.
It sounds like a mechanical contact problem.
The antenna is connected to the PCB with a wire, if I remember right.
May be, this wire is loose. You can open the case of the theremin and proof this.
It should not be difficult to repair this. You should check whether there is good contact.
Either the contact to the antenna is loose, or the contact at the other side.
There were two types of etherwave with small differences, how the antenna is fixed.
Did you ever try to rotate the antenna? It is relatively long and the forces are high applied to the wooden box. You should avoid this.
Best regards
Bernd
Hutschi
Postby Chrissie » Wed Jan 17, 2007 8:32 pm
anyone succeeded in solving this problem?
Chrissie
Postby Willyman » Sat Jan 17, 2009 4:27 am
It could be the volume oscillator. When yu touch the antenna it resets to zero, and starts it's cycle again, sending a single audible pulse, which I suppose only happens when you turn the thing on. I wouldn't know how to fix it, so if the problem arises I'd just tune the volume so its silent befor you touch the antenna, and avoid touching it.
Willyman
Postby EricK » Sat Jan 17, 2009 6:09 am
Actually I called tech support back then and they said that its just the nature of the sensitivity of the thing. I haven't noticed it alot, but I don't play my theremin a lot either. I think if you really get to boosting the signal youll hear all kinds of ghost tones and stuff.
It works like a dream when I do play it.
Thanks for reviving this old thread lol.
Return to Theremin Forum
Who is online
Users browsing this forum: No registered users and 0 guests
