Matriarch osc retrig
obefreq
Post by obefreq » Fri Sep 22, 2023 1:59 pm
Is it any chance to re-trig osc every time u press note or when new note comes from daw?
With my Dominion 1 when I connected gate out with sync in. It reset osc. So every new cycles start from zero cycle.
Is it possible on Matriarch. Ive had in a past Subphatty and it was possible there.
obefreq
Re: Matriarch osc retrig
Post by obefreq » Sat Sep 23, 2023 10:24 am
Anyone?
Synth.builder
Post by Synth.builder » Mon Sep 25, 2023 8:31 am
obefreq wrote: Fri Sep 22, 2023 1:59 pmIs it any chance to re-trig osc every time u press note or when new note comes from daw?
Sadly not. The only sync function is from the other oscillators for traditional sync timbres.
pmumble
Post by pmumble » Mon Sep 25, 2023 10:23 am
Only for the modulation oscillator.
obefreq
Post by obefreq » Mon Sep 25, 2023 10:53 am
Can you check when you connect gate output to sync input and use osc 2 only is te cycle starts from zero cycle/osc retrig? Can someone check it for me please.
Cheers
sdwillingham
Post by sdwillingham » Wed Sep 27, 2023 1:21 pm
obefreq wrote: Mon Sep 25, 2023 10:53 am Can you check when you connect gate output to sync input and use osc 2 only is te cycle starts from zero cycle/osc retrig? Can someone check it for me please.
The answer is no. The main oscillators on the Matriarch do not have “sync input” jacks. So they cannot be synchronized in any way other than provided by the panel switches. The documentation can be downloaded from Moog’s web site.
