Power supply pedal??
Hey folks I have a Paul vo flame top model, I don’t have the power supply/expression pedal or the cable. It also needs some sort of electronics servicing. Anyone know where I can get the pedal /power supply and it’s magic cable? Or someone qualified to do some work on the electronics?
Re: Power supply pedal??
Did you ever get any help with this? Moog might have some power supply/pedals. Servicing is another matter, entirely. Contact Paul Vo for a reference, maybe?
I have often thought it would be wise to have a backup pedal.
The cables are easier to find. They are used in lighting systems, I've been told.
Hi, as you know most guitar pedals require 9V power (even many multi-effects pedalboards). ... Keep in mind that while most guitar pedals use 9V, there are pedals out there that require a higher voltage. If you have a pedal that requires 12V, 18V, or even 24V, make sure the power supply you use matches that voltage.
Gustavo Woltmann :UK based guitarist in a rock band
