playing over loops on the LP
is it possible to create a loop with arpeggiator then play over the top of it just using the funtions on the Little Phatty or do you need a looping pedal ?
Re: playing over loops on the LP
You would need a looping pedal, or multitrack it.
The synth is monophonic, so it can only play 1 note at a time... therefore if you tried to play over top of it, it would just steal notes from the arpeggio... though on the lp if you latch the arpeggiator and play a new note, it will just arpeggiate that new note... so, no, u can't do that. Looping pedal, or just record 2 tracks with multitracking software.
Moog Voyager RME / Moog LP SE 2 / Nord Rack 1 / Microkorg / Korg ER-1 / Triggerfinger / Rocktron Banshee talk box / Ableton live / Guru / Lots of non-electric musical instruments.
dumb question seeing that it's monophonic, duh....... thanksanoteoftruth wrote:You would need a looping pedal, or multitrack it.
