My LP is dead
My LP is dead
I attempted a firmware update last nite. To make sure I had good midi cables I sent my sounds to my laptop, reset the board, then sent them back to the unit. Everything was ok.
Use MIDI-OX to send the Stage 2.2 OS and walked away. Came back to a Cycle power error. Cycled the power thinking it would ask for a reload, now all I have is a blank screen.
Re: My LP is dead
Amos to the rescue! Contact Moog Support, it should be fixable without returning it to the factory.tonedefmusic wrote:I attempted a firmware update last nite. To make sure I had good midi cables I sent my sounds to my laptop, reset the board, then sent them back to the unit. Everything was ok.
www.ctrlshft.com
Re: My LP is dead
[quote="CTRLSHFT
Amos to the rescue! Contact Moog Support, it should be fixable without returning it to the factory.[/quote]
I called and spoke to Ryan today. He suggested I return it., then mentioned something about a $35 debug adapter.
Re: My LP is dead
I called and spoke to Ryan today. He suggested I return it., then mentioned something about a $35 debug adapter.[/quote]tonedefmusic wrote:[quote="CTRLSHFT
That's pretty sucky, but glad they have an alternative to a factory return.
www.ctrlshft.com
I followed the instructions, setting MIDI OX to 1024 or something to that effect, I have the instructions on my other laptop...I used a MIDISPORT UNO...I downloaded the file and instructions directly from the moogmusic site.Amos wrote:did you make sure to set the buffer size correctly in MIDI-OX before doing the transfer? That could have caused this error.
-T
My Little Phatty also died THIS VIDEO i made may give you an idea how easy it is to use a debugger.
[url=http://www.canecreek.co.uk/]canecreek.co.uk[/url]
De bugger failed to work
Hi, my debugger arrived today and I have this message appearing 'communication could not be established with the specified adapter. Please confirm the current adapter and cable connection'. Can anyone help, I do not know what to do next - any advice please?
Did you download the 'Flash programming utility' from HERE ? (bottom of the page)
You need to install the 'flash programming utilitys' on your PC before you can use the debugger.
