If I reset all patches using "Restore Factory", will it restore to 1.0 or restore all patches/settings as of the 2.10T which is currently present.
Assuming the latter is the case, will all of the factory presets have SOME arpeggio setting or will I need to modify the parameter for each patch that I wish to enable arp for?
Having recently rec'd my 2.10T back from Moog, I somehow expected to have a new set of (Stage II-like) patches and having painstakingly backed up all of my original patches, plus the ones I've created, I was prepared to have a large library now.
I suppose for those that don't back up their patches, Moog is doing a great service to restore them after upgrade (I've seen a few posts where this is not the case); I'm after the opposite.
Final question, will Restore Factory, set all of the calibration back to zero? (ie, will need to re-do it again).
Thanks.
Question about "Restore Factory" function
Not all OS 2 patches are programmed with arpeggio. It is relatively easy to add the arpeggiator function to those patches that aren't pre-programmed with the arpeggiator.
I think all of the OS 2.10 factory patches do have arpeggiator programming set-up already. They are the same actual sounds as OS 2.0 but I went in and set up the arps.
By all means if you have your patches backed up already, do a Factory Restore -- you'll get all the Stage II presets (with arps, if my memory serves), plus it will not mess with your calibration settings. Calibration is retained through a Factory Restore; only preset and global settings are affected.
Amos
Amos
I haven't really played around with OS 2.2 as much as I would have liked. I would imagine 2.1 and 2.2 are the same arp settings, yes? After playing around a bit, I have discovered that all presets do indeed have arp settings now. Thanks Amos!
