since updating to 2.1 whenever i activate the arpeggiator my phatty cuts out, no output signal at all!!! and as soon as i turn it off the arpeggiator again sound returns...
anyone else had this at all??
any ideas??
no sound with arpeggiator
If arpeggiator clock source is MIDI, and you are not sending a MIDI clock to the LP, it will not make any sound when the arp is on. Also, if you updated from an old (pre-arpeggiator) version of the operating system, you should probably do a Factory Restore to make sure all global settings are correct.
Be sure to back up your presets (if you have any custom sounds) before doing the Factory Restore, as it will replace all presets with the original factory sounds.
