Hi
I'm new to the world of MIDI. I'm able to use my LP to use the software sounds in Garageband through my USB port but so far am unable to somehow interface my LP to hear/record its own sounds in Garageband.
Will I be able to do this straight through USB? Or can I only use the USB to have the LP as a controller? If so, how do I get my LP to play its own sounds into Garageband? By going through a mixer?
Thanks.
Newbie question - recording LP into Garageband
Re: Newbie question - recording LP into Garageband
USB only transmits MIDI with the LP, you will need an audio interface to connect to the DAW [Garage Band] with.juliussharpe wrote:Hi
Thanks.
www.ctrlshft.com
Or, if you don't mind clipping, you can run the Audio out from the LP to the Audio IN of the Mac's soundcard. Are you using a MacBook? If so, the input is next to the headphone jack. To avoid the clipping, run the LP to a mixer first, and run the mixer to the audio in.
