and what parameters precisely you want to control? since you already have a knob/button pro function, and the menu parameters are not exactly useful playing real-time.. at list not for me.dada wrote: as title really
....all the LP parameters in real-time?
anybody using a midi controller to edit LP patches?
Re: anybody using a midi controller to edit LP patches?
From what I understand, most front panel controlls can be controlled through midi. I think all the controlls that send midi can also be controlled by midi. The user manual lists all the midi CC messages sent by the LP and their range on p. 44-45. In OS 2.0 the mod wheel and filter cutoff also are able to transmitt 14-bit midi and aolso recieves 14-bit. This is in the 2.0 users manual addendum on p.3
Controlling some parameter through a midi controller will cause you to lose Moog's proprietary RAC (real analog control). In the Stage Edition,
RAC provides responsive analog control for the Osc 1 & 2, Filter Cutoff, Filter Resonance, EG Amount, Overload and Filter EG Sustain parameters. I think the tribute has more parameters that get the RAC treatment, but I do not know which.
I am going with a midi foot controller to augment the controll surface offered from the LP. I want to be able to change mod sources or destrinations without paging through all 6, change presets, or if I want to change 2 parameters in one section at the same time.
Sir Nose wrote: I am going with a midi foot controller to augment the controll surface offered from the LP. I want to be able to change mod sources or destrinations without paging through all 6, change presets, or if I want to change 2 parameters in one section at the same time.
that is interestnig!
